Okay, as a long-time runner, have been plagued on and off with significant plantar fasciitis, usually manifest as pain in the calcaneus and lower heel, and it usually responds to a series of stretches.
That was then - this is now. It’s back, and with a vengeance - and is along the posterolateral heel, well up into the achilles tendon - I have been stretching, doing a series of myofascial release techniques, using antiinflammatories and ice - and actually (heaven forbid!!) took 5 days off of running.
Went out and did 7 easy miles this morning - some hills and some drills, but pretty mellow, all in all. And now I’m in friggin agony. I see a couple of weeks of bike & swim, with no running - but am desperate for some suggestions. To the sports med gurus, should I be worried about something more significant than garden-variety tendinitis?
Freeze a cup of ice and massage the area. Do it several times a day for as long as you can stand it. It takes an insane amount to do much good (at least for me) but it does help. That will treat the symptom.
Go see a good podiatrist who specializes in runners. A good pair of orthotics did wonders for my game. Those guys are worth their weight in gold.
Hmmm … posterolateral heel pain is an uncommon place for plantar fasciitis since the main insertion point of the plantar fascia is on the medial calcaneal tubercle (although a small lateral slip does insert on the lateral tubercle). Does the achilles tendon itself hurt with palpation? Any crepitus felt along the paratenon? Or is the pain just directly near the insertion. Also, any subtle edema or eccymosis? Lastly, sqeeze the heel laterally with your palms - ouch? Calcaneal stress fractures/reactions start to manifest like this …
I agree with the uncommon nature of the pain - although similar in nature to the last time I had it (I actually thought I had a tear of the soleus at one point). The tendon hurts on palpation, and is tender posteriorly both on palpation and compression. No crepitus, no obvious edema and no ecchymosis. No pain at all when I compress the heel / calcaneus itself, either laterally or pressing up from the plantar surface. The most acute pain is actually about 7 - 10 cm above and lateral to the insertion of the tendo calcaneus onto the bone, and occurs with any twisting motion.
This was the ankle I fractured snowboarding a year ago, but that was a distal tibial fracture, and somewhat spiral (the dumb result of trying to go too far riding on my stomp pad and not strapped in); but the pain pattern is, save for the location, very typical plantar fasciitis as I’ve had it before.
Well, that just sounds like “garden variety” achilles tendonitis. If no palpable fibrosis or nodule yet, you just earned some time off Time to work on that swim doc … Shouldn’t be any correlation to your SER-II ankle fracture (casted, or ORIF?). Usually just from overtaining and/or tight gastro-soleus, rather than local heel counter irritation up that high.
Good luck! Oh, and easy on the eccentric calf exercises (that I think you know how to do) until it is non tender to touch, then ease into them
Thanks - very reassuring.
The Fx was casted (the triangular fragment was attached distally and union was very quick - final X-ray looked great) - and I managed to get in a few races last year, including a 1/2 IM.
yeah, I am resigning myself to some time of swimming, biking, icing and resting.
I struggled with Achilles tendinitis and calf realated issues all Fall. I think you are looking at taking some time off running first, perhaps three weeks. You said you came back and did a 7 miler. Wrong move. I know, because I came back a couple times and did 8. You have to really nurse this thing along patiently. I started running again on a track 2 miles super slow (after a four week layoff of no running at all). Use a small gel heel lift in your shoe. After about a week of runnning two miles every other day, I went to three. Always, ultra aware of the injury and whether it was worsening, staying the same or getting better. When it wasn’t getting worse, i moved up to 5 miles, where, i am now. I also, made sure, any running I did do was on the flat. No hills whatsoever, and even, smooth surfaces. In addition to this i iced, stretched and gently strengthened. It’s a bitch, but you are injured and this is a bad one if you don’t take it conservatively on your return to running.
If you have good insurance, and if your pf is recurring, you should SERIOUSLY consider ESWT. I had a case of pf in 2004 that I thought would end my athletic career - I’m not exagerrating. I had ESWT, had 13 weeks of recovery, and have been 100% pain free since. I can’t believe I dealt with it for so long when a permanent fix was so simple (except for the lengthy recovery period, which in itself almost killed me). You can do a search for ESWT if you need more info, or PM me tonight (I rarely come on ST, so tonight’s probably it for a month or two).
Since we are talking about treatments with initials, I have had great luck with ASTYM. I have benn getting twice a week tratments through a PT for a month and the AT feels about 90% cured.
