Planet X 82/101
What valve extenders (size and brand) do you use with these wheels? What tires do you recommend? Glue or tape and what kind?
Valve extenders depend on what kind of valves you will get…replaceable stems or not.
Ideally, get tubes with 90mm valves, and a 30mm extender for the rear and spare.
I am looking for the way people have set these wheels up. I want to know what has worked well for people that use these wheels.
I am running 1 60mm for the front and 2 40mm for the rear.
http://i1071.photobucket.com/albums/u505/erichowser/null_zpsdf6e579c.jpg
Sweet bike! The black and yellow look awesome together. My Infinite Multisport Triathlon peeps would appreciate the colors. Tape or glue and what kind?
Rule of thumb is that if you have tubes with “normal” length valve stems, i.e. 38mm, then buy valve extenders the same depth as your rims. This ensures you have enough valve stem to get the pump head on.
They are glued on. A buddy of mine, who owns the shop where I bought this bike, charges only $7 each wheel to glue them up. That’s too good of a price to mess with them myself. I don’t know what brand he used.
