Looking for a white tri suit for IMCOZ…can t find any!
Idea?
thanks
Idea?
thanks
My suggestion is avoid a all white tri suit. Think about it, when you get out of the water, or throw water over your head, more might be showing then you want and everyone else wants to see…
OK - it won’t be long for a certain podium shot to surface …
Skinfit makes one that looks really nice:
http://www.skinfit.eu/index_hot.asp?gruppe=6&land=US
Click on shop at the top and then tri on the left - I can’t find a way to link directly
Kiwami has a limited edition Amphibian which is mostly white.
Click on the ads featuring Jordan.
Did someone say White Tri Suit? =)
http://www.youtube.com/watch?v=iLtos4aWYy0
(the new anti rick-roll)
Best case scenario: everyone will see your junk. Like, REALLY see it.
Worse case: you’ll have a case of violent diarrhea and the explosion will be obvious in your then 2-tone shorts.
Have fun with that.
the problem with white is that you need to have a really good fabric that is not see through and it should be a little bit on the heavier side.
