I have a Cervelo P2Sl and it’s beautiful. I LOVE it! (and no, it wasn’t a gift or discount. My powers of persuasion aren’t that good!).
But my first bike was a Cannondale R400 so I have a soft spot in my heart for Cannondale.
Jodi
Jodi
If you are going to keep the front brake you will want to tick a dummy brake on the other side, it’s awkward and uncomfortable to ride with just the one on unless you are ALWAYS on the drops.
Thank you for the tip. I thought the lbs was going to put a dummy brake on the right side for comfort, but, the builder left it off. Being new to the single speed/fixie scene, I figured that is how it was supposed to be set up. However, I will add the right brake handle. How do you “fix” the brake handle so it doesn’t flap around b/c it is not attached to a cable?
Nice bike, but… if you are going to use it as a single speed, I’d recommend putting a rear brake on there as well. If you are just going to be using it as a fixie (my recommendation is go the pure fixie route) then you may want to run a rear brake if you have any significant hills. Right now my fixie just has a front brake, and there are a few descents where I get a little unnnerved. A rear brake would be nice for modulating speed a little better, as it is almost impossible (for me) to brake using back pressure on the pedals at 150 plus rpm.
Oh yeah, your seat is too high, and your dogs shed too much.
Either just have the hood or get a lever with a return spring so that it sits on position.
