Since the search engine is down, I’ ask the question again.
If you had to choose one pedal system for your road and tri bike what woudl it be and why? FWIW i have spd’s right now and think that they function fine once clipped in, but are a apin to clip into and weigh about a 1lb a piece.
I will be buying two sets of pedals so I want to stay away from the really pricey ones (nothing like having to explain a $700 pedal bill to my wife).
I know a lot of you ride speedplays, but I worry about clogging the cleat with grass and mud running out of T1 and scraping it up skidding into T2
I think that the Crank Bros pedals looks interesting but wonder about the feel.
I see a lot of Looks out there, but worry about the stack height of that huge cleat, and also about the durability of the plastic (see skidding into T2)
If you keep your shoes clipped in and then slide into them on the bike and slide out of them on the bike you won’t have to worry about breaking or clogging the cleat. This will also help your transition times.
I ride speedplays and love them. I have also ridden time carbon RSXs they are good pedals too, but the adjustable float was the main reason that I went with the speedplays.
I’ve been a Look person for more that 20 years now.
Occasionally, I’m overcome by my heavily suppressed fashionable side, and am tempted to switch to Campy, solely on style. I never pull the trigger…
But from a functional point of view, the smartest switch for me would probably be to Time, both for the road and MTB. Just seems easier, from the standpoint of having the same cleats on all shoe types.
I can’t help you on the T2 concerns with regard to cleats. As far as tri goes, pedals are the least of my concerns!!
I do the same thing and ride speedplays for the same reason but admit I spend a lot of mental energy going over all of this in my mind prior to racing. i.e. remembering to keep the bike straight while getting my feet in and out and not knocking the shoe off the pedal coming into T2 I lost a shoe once in T1 and didn’t realize it until I was 100 yds away (through the mud) and mounting my bike. Talk about looking like a jackass.
Speedplay on all my bikes except some Crank Brothers classic eggbeaters that I also love on my MTN bike. The Zeros are great - dial in whatever you want and they don’t foul as bad as the classic X-series. Super light weight as well. Great cornering clearance for crits (if this matters). I’m so used to the dual sides entry (4 sided entry on the crank brothers), that whenever I use “other” cleates for some reason, I’m amazed at how much more difficult it is to clip in. Doesn’t much matter for a tri since you should only do this once, but for road riding with all the stops, it is nice.
Wide range of cost too. Only the Ti models are what I’d consider pricey. The SS ones are just fine.
I have Crank Bros Quattro SI’s and love them. Granted, I’ve never used anything else, so I don’t have anything to compare to, but they don’t clog, in a pinch you can ride them with regular shoes, and you can clip in from either side.
How would you describe the difference in feel between the SP and the eggbeaters?
I currently only have road shoes and don’t know how feasable it is to try to get into them while riding down the road. Plus I know that some races do not allow you to leave the shoes clipped in.
I used Speedplay X series on everything. Then, last fall, I managed to send a shoe flying coming into T2. I retrieved my shoe, only to later discover that I’d retrieved someone else’s shoe. Hilarity ensued. I loved everything about the Speedplay X aside from the ease of inadvertently unclipping. I went on a quest similar to yours and was ushered toward the SPD-SL series by my LBS. I’m happy with them, but the change from infinite, slippery float to limited, sluggish float was initially off-putting. Running in speedplay cleats is not fun. Had I not been satisfied with te SPD-SL, Time was next on my hit list.
Speedplay on both my road and tri bike. I don’t love the cleats when running in our out of transition, but after trying other pedals I returned to Speedplays. I figured 20 seconds of imperfect running was worth it for miles of comfortable riding. I’ve never had a problem clipping in or out either on purpose or accidentally.
I have to say that I just switched to the Crank Brothers Eggbeaters and thus far love them. Even if you miss the pedal with the first try, I haven’t had problems getting up to some kind of speed and then clipping in. (only been riding them for a few weeks so the clipping in and out thing isn’t as smooth as I would like.) Also, the road cleat for the eggbeaters is incredibly low profile and easy to walk in. They are also really comfortable while pedaling.
-____________________________________________________________________________________________________________
The speedplays feel much like they are clipped in much “tighter” for lack of a better term. I can never quite tell when I’m actually clipped in with the egg beaters, but I usually am. I think part of this is the huge difference in shoes with the recessed cleat though. The Crank Brothers cleat definitely unclips easier with any transverse plane motion, which would make transition one leg standing, etc. very dicey. But, as was mentioned, running on the speedplay cleats suck (although I’ve done so for years) where the Crank Brothers cleats are minimal and running is easy.
I use Shimano Ultegras on my road bikes but for some weird reason that I can’t explain I’m considering giving Look Keo carbons a shot on my tri bike. I have no idea why I’m considering doing that because I’ve been very happy with the Shimanos… of course Dura Ace pedals are on sale at all3sports so I may just grab a set of those.
I just recently purchased the Time RXS carbon for my tri bike and the regular Time RXS for my road bike. No complaints so far. the cleat is a little lower profile and less chance of getting dirt, etc caught in it. I am logging mostly computrainer miles right now…no long rides w/ them yet. Pretty good price, though, w/ a lot of nice features.
Matt
Do you notice any difference in feel between the carbon and standard versions? Are they equally tight and solid?
I haven’t noticed any difference. Very close. I have to admit there is probably no noticeable advantage to the carbon ones…but I thought they were cool. the standard ones are about $50 cheaper, too.
I have Speedplays on my tri bike and LOOK on my road bike. I appreciate different aspects of both brands for different reasons. One thing I can’t stand about Speedplay are how expensive the cleats are ($40 at the local Performance shop) and in my experience replacing them every other season makes the difference between clipping out on accident or not.
i have rxe’s on my training bike, and rxs carbons (steel axle) on my tri bike.
there is no difference in feel between the two although the rxe’s are non adjustable for float tension and according to the precision scale at work, the cheaper pedal is lighter!!! go figure?
nb, the only reason I went for the carbons, is I got offered a brand new pair for less than the retail on the rxe’s, ( although the black carbons look very nice on my plasma)
For something totally different, you could try side moutn pedals. They’re not for everyone. they haave a negative stack height and an increased Q (although the pedals are conted in to accoutn for that.) You can run them, Well, not for the run race, but ok to run through transition. The engagement in NOT on the bottom of the pedal/cleat. I have them o my road and tri bikes. They are definitely NOT for everyone, but…
