I have always been of the understanding that the toes and forefoot are completely passive in the pedal stroke. Rather, the toe box portion of the shoe should not be actively pressed through the stroke.
For what it’s worth, I have seen elite cyclists who have strokes that run the gambit. Heel droppers and toe pushers, both going REALLY fast and arriving in a hurry.
I wonder if it’s more a factor of what works best for you?
For instance, I have had two separate fitters confirm for me with power meters indoors and out that aggressive seat tube angles not only rob me of power, but cramp up my legs hammys/back and are not the way for me to go. I’m a weirdo or sorts, but slamming my saddle back to 73ish and sliding up the saddle a bit works perfectly for comfort and power, but flies in the face of modern TT philosopy, or at least in some circles.
Has anyone used the CompuTrainer? My buddy has one and it has this little meter scale on it to tell you whether or not you are pedaling with even torque throughout the stroke, pedaling circles if you will. When I’m in a relaxed saddle position it’s just dead nuts ‘circular’, but anything else and it gets choppy and ‘squared’ in motion.
dont worrie AT ALL about how to pedal. Biking required about no technique… it s a very simple action where your feet are lock to the pedal and have nowhere to go but in circle so just let the body guide you. There is no power to gain from ‘‘knowing a special technic’’
also, to some extend, if you have a good fitter that position you, you should not get rub of your power at a steeper seat angle. Those fitter might be missing something in there understanding??? There is nothing wrong with riding at 73 degress…but most case, it end up been a not very aero position at those angle and end up been less than optimal to go fast… Even losing a bit of power but at 78 degrees and nice clean aero position will be much faster.
Something good to play with …with a good fitter. That said, i beleive there isnt many good fitter and it s a challenge to find them…
What is especially interesting to me is it seems to me that cycling is the only sport in the entire world where people will claim that technique doesn’t affect performance. Why anyone would believe that is beyond me. The fact that they don’t know what is superior or not or that there is no concensus as to what constitutes “optimum technique” is not evidence that there is not an optimum technique or that some techniques, while not “optimum” might be better than other techniques.
Oh I definitely believe in technique. I used to pedal ‘squares’ until someone taught me I was wasting power. It’s like taking medicine at first, but now I don’t even think about it. I just don’t know how big a change it would make to my power output/energy if I tried to turn circles using my toes as part of the lever. My toes actually feel light and ‘floaty’ inside my shoe, I literally use none of them unless I’m climbing and way out over my front hub grinding.
Would love to read/see/hear some data on ankle flexion/toe input on the pedal stroke.
the problem is, those fitters did not really understand what was going on.
because, in most cases, seat angles per se do nothing.
it is the hip angle that affects power.
and if you have an optimal hip angle range, you can get that range riding shallow, or steep.
The ‘entire world’ is an overstatement. When I was fit, he was looking at my pedal technique and spin scan - Told me that I’m not pedaling in circles and I’m wasting watts because of the ineffieiency. You’d never guess what he recommended to improve my technique… Maybe get a ST lashing for this - but every awesome cyclist I know preach PC’s in the offseason. I know some who do 3hr group hammerfests on them. It seems to me that only the triathlete community thinks they are blasphemous.
Well, I certainly don’t know of any other sport where advocates of that sport think technique is not important.
And, regarding PC’s, it is only a portion of both the triathlon and cycling communities that think of them as blasphemy. Some of the more vocal ones hang out here.
Wrong again Frank. They don’t think of them as blasphemy. They think of them as BS.
You routinely get laughed off of the cycling and running forums to the extent that I don’t see you posting much there anymore.
Strike 1 - paying for the fit
Strike 2 - paying for a fit from someone who thinks spin scan is meaningful
Strike 3 - believing PCs are the only way to improve power
I’ve never heard anyone say that cycling technique does not affect performance in cycling.
-Drafting/pack riding technique is essential to being a successful cyclist
-Cornering/descending with good technique saves seconds with every bend in the road for roadies and triathletes alike.
-Smoothly and quickly reaching for food/liquid while staying aero is technique that is beneficial to roadies and triathletes.
Some say that the technique of unweighting pedals on the upstroke doesn’t improve performance. Others, mainly those without benefit of a power meter (or with something to sell), say that unweighting provides benefits.
You’re out!
You’re way off base here - and obviously a hater.
Paying for fit??
Not mentioned in my post. Could you explain how you arrived at that conculsion??
Thinks spin scan is meaningful.
You are correct, he felt it could be improved.
Believing PC’s are the only way to improve power??
Again - is this what I wrote?? It actually says offseason. I should then conclude that YOU believe that power can only be improved in the offseason…
You’re out!
Paying for fit??
You’re just a hater.
He’s not a hater. He’s speaking from experience.
Paying for fit??
Actually I’m a lover, not a figher.
I’ll grant you that. You didn’t mention it, and I hope you didn’t pay for that sage advice.
So we agree, spin scan is about as useful as the using the number of hairs on your knuckles to predict the weather?
The logic would be: A) PCs improve efficiency, B) increased efficiency means increased power, C) use in the off-season. Thus, A+B+C: Using PCs in the off-season will improve my power.
On 3), I actually think that PCs “can” increase power for a rider, be it in season or out-of-season. But then again, so can not using them. IMO, you can get to the same end point with or without them. They aren’t magic.
Anyway, back on topic if you look at the pro peleton you’ll see all sorts of pedaling styles (as well as seat position relative to the BB and pedals). In other words, as jonnyo said, don’t worry about it.
Is technique important? Sure. But to suggest one way is better than other does not account for the natural kinematics of the rider. No two people are alike, so why force someone’s motion on someone else?
As an example, take baseball. The pitcher needs to throw the ball from the mound to the plate. We would argue technique is awfully important, wouldn’t we? Yet you’ve got variety in pitching action (over the top, sidearm, submarine, …) and motion (hitches in the delivery, how the pitcher comes off the rubber…). Is one better than the other? Don’t know. Can a pitcher who naturally throws over the top get injured if forced to throw sidearm? Probably so.
Let your body tell you how it wants to move and ignore the rest.
Paying for fit??
I could add some clarity to the picture (the kids are still napping, so I have some time…):
I have no idea how it matters, but I did pay for the ‘fit’: Afraid to cut the seat post on my new frame my buddy helped me measure, cut, etc… (He’s a cat 1 racer and mechanic). As we dialed in the details, I was on his computrainer. When I brought it up to FT ~300 watts he said ‘look at the screen, your spin it getting sloppy’. I use a powertap and never used the computrainer before, so it was cool to me. We messed around a bit with some cleat positions (motocross=2 broken knees) to see how spin was affected (it wasn’t). The response was basically - try powercranks! A couple $$ for his help measuring/cutting seemed appropriate, he is a mechanic. My buddy is a PC advocate and I respect his knowledge.
My personal opinion is the same as yours, with the caveat that I’ve never used them (IMO a big caveat).
I’m just shocked at how polarizing the debate is.
whenever people observe that pros have a variety of techniques/strategies/choices
people always wonder like you do, if its a matter of what works best for you.
i always wonder, if its a matter of it not mattering.
my way certainly is more relaxing. since you don’t have to worry about it and just go ride.
Johnnyo didn’t say “don’t worry about it”. He said it required “no technique”. I would agree with the concept of “not worrying about it” if one isn’t going to take concrete steps to change things, because it is so difficult to change. But to say that pedaling technique has zero influence on how much power one can develop is put sillyness. The fact that pedaling technique is all over the place in the pro peloton does not go to the question as to whether there is an optimum technique. Whether you agree with me on what I think is optimum or some other style (just push harder) as being optimum, clearly the rider who is trying to optimize power should “worry” about it. If they don’t care about optimization but simply will accept what improvements come their way then “don’t worry about it”. And, what is optimum technique for one person may not be for another using your baseball analogy. Same is true in pedaling I presume, although a little less so because the motion is constrained to a circle when pedaling, not so when throwing a baseball. Plus, throwing a baseball in an “odd” fashion could give the pitcher an advantage since the batters may be less used to it so they may not be as capable against it. The pitcher is trying to outwit the batter. The same can not be said about cycling, that pedaling style can be used to “outwit” an opponent.
Paying for fit??
spinscan can be a useful tool but it does not measure “circular pedaling”. It simply measures smoothness. His pointing out your getting “sloppy” is useful to know. It didn’t tell you why you were getting sloppy but being “sloppy” in your pedaling but surely no one here would say that being “sloppy” is ideal. Also, to those who say “technique” doesn’t matter, why aren’t you still using platform pedals?
