Pedaling Downhill?
Is it better to pedal downhill during the bike for an IM? or is it better to coast and use it as a little rest? Looking for the most efficient, the bike is my weakest and will probably take me 6-6 1/2 hours. Seems like most cyclist continue to pedal downhill.
always put it in a larger gear 53-12 and fly down that hill. If thier is another up hill that follows the faster speed will carry you farther up the hill, then shift to an easier gear and fly past the others that were resting on the last hill. It will help you pass more people on the portion that people have the most trouble with, and it will boost your confidence at the same time.
Jeff,
I think it is important to continue to pedal over the top of the hill and then start shifting thru the gears until you reach about 34 mph. At this point, tuck and coast until your speed slows below 34, and start to pedal and shift back thru the gears until you reach your normal speed/cadence. This is especially important on rolling hill sections where you want to build speed to climb the next hill.
Gar
Thanks, that seems to be what I see other people do. I will give it a shot on this weeks long ride. I suppose this is where a power meter would be most useful.
34? Is there a reason for that exact speed?
For me depends on how I’m feeling. I ask my self, I’m I looking for free distance or free speed. Since I race BOP train by myself, I’m just really racing against myself & keep a close eye AVG MPH. If I feel good I go for the free speed to bump up my AVG MPH, if I’m beat & just looking to get of the bike I coast & consider it free distance.
Yes, it is based on 80% of your resting heart rate, adjusted for age or your BMI plus 10, whichever is higher. I got this calculation from a tri coach, so it must be right!
Actually, for me this is the speed where tucking will be faster. If I pedal people in a tuck start to pass me.
Thinking about it the magic number for me seems to be 33. I pedal till I get there then tuck. I come back up after dropping to 27 though.
I ride with a couple of old, wise and fast roadies up here that will scream past me in a tuck like I am standing still if I pedal at high speed. It only had to happen 50 or 60 times for me to change my strategy and tuck at 34 mph like they do.
Gar
