Pedal Question: Floating or not?
I am going to replace my look cleats, which one is better for tri? Floating or solid ones?
It’s not a question of which is better for tri, rather which is better for YOU. Fixed vs float (as well as the degree of float, auto centering or free float, float tension, etc) is a personal issue that you need to work out - either by yourself, or with the help of a good fitter. Personally, I like fixed cleats. Most people prefer float though.
I completely agree with you. It is not a question of tri. Each rider will require a different setup.
I used fixed and thought it was fine. But once I moved into long distance my left knee felt slightly uncomfortable (not painful) once I was riding more than 3 hours. I changed to floating (Shimano Ultegra) and the problem was resolved. So for me some floating feels better.
Of course too much floating is also not good.
So I will refine the question as - how much floating does one need (starting from 0 degrees)? And my answer is that a proper process should be used to find what suits a particular individual. I believe that the best solution is an adjustable system that allows you to refine the process iteratively until you find the correct setting. As far as I know my own pedals are either fixed or not – you can’t adjust the degrees.
the speedplay zeros are adjustable float but once I switched away from them to fixed Looks, my problems seemed to go away. I switched again to shimano SL’s and seem ok, but I didn’t really go on super long rides. I felt something but I wasn’t sure if it was in my head or not.
so to add to this thread, I say go floating as 90% of the population seem to prefer, but keep in mind that if you do go fixed, find a fitter who has one of them cleat positioning thingees. Otherwise who knows what you’re twisting your foot into…
Agreed.
It really depends on the riders/users needs. Float is good for some just as fixed is good for others.
What I found interesting is how the tri community seemed to completely embrace full-float cleat systems while many of the absolute best cyclists in the world remained on fixed systems. Like fully supportive running shoes, I suspect that some triathletes are riding with full float systems who may be better off in a fixed set up, but may not even know this and won’t until they get some form of injury.
I used a fixed Look set up for years and never had any problems. However, a few years ago I switched to the Look red cleats with the limited float option and this seems to be working for me now. My rational was that I was getting older. Knees where getting a bit achy from time to time and I was riding less, but just as aggressivly on these now infrequent rides. I have been having no knee problems, so it’s all good.
Fleck
Can anyone explain what type of injuries could be expected by using a pedal with too much float? In my simplistic mind the float allows your body to find what position is most comfortable/natural.
As I understand it, using the float variety will hamper your long-term swim-stroke training :wink:
I like some float, it gives me the choice to vary my foot position periodically on long rides…you know, toe in a little or toe out a little for several strokes, then go back to whatever is natural for my foot to do. It’s not exactly like stretching, but, it gives my leg a slightly different feel that feels good to do on long rides.
I had knee problems for 10 years before I switched to Time pedals in 1991. It was a revalation for me— All of a sudden I could train as hard as I wanted in whatever gear I wanted without knee pain. Since then, no problems at all. I swear by systems that allow float.
A bike fitter can do alot, but many people’s natural foot position changes throughout the pedal stroke so cleat floating and rotational freedom are necessary to accomodate that motion, no matter how good the fitter.
-Marc
When I asked this question, the answer I got was stay with a moderate amount of float unless you know you need fixed. It sounds like good advice to me.
tom wrote: …stay with a moderate amount of float unless you know you need fixed.
Dang, tom. Serious. Accurate. Concise. Don’t you know how to miscommunicate on the internet? You’re going to give the internet a good name if you keep up this kind of nonsense! Stop it, now!
