PC Question for Tom D
Tom,
I was looking through some older threads here on Slowtwitch from Dec '02/Jan/03. At that time you were an advocate of powercranks, even referring to them as a “secret weapon”. Are you still using them? If not, would you mind sharing your decision to stop using them?
I only ask as I am this far, >.< from purchasing a set (and that’s close!).
Regards
I’d say if you’re close get them. What’s holding you back?
Not Tom, but I picked up a pair of the variable length ones in in Aug & haven’t thought twice about it since. I just hate to waste money. I got them more to help reducing running injury since I’ve been in PT for a few month for that. Just the other night I was thinking they might have paid for themselves. instead of 4 PT visits.
I’ve been playing with the crank lenght on one side that I have a significant leg discrepancy. I’ve ridden the same course on the CT with different crank lenghts four times over 3 days without any concerted effort, just zone 2 and my speed > from 16.7 avg to 17.3 with a drop in time from 1:11:58 to 1:08:23. Then a “normal”, not pain producing run later that day. I’m still learning how to use them so can imagine there will be better improvements ahead.
Do a search on the forum for powercranks & you will find a lot of positive and helpful information.
Barb
Oh man!!! Here we go again!!!
jaretj
Barb, what range of crank lengths did you try?
Thanks for the reply, I’m Just waiting for a bonus cheque to arrive in the next few weeks, then I’ll be ordering.
Jaretj,
I hear you, but I’ve no intention of revisiting any PC/RC debates. I was able to “test drive” the PC’s at IMLP (I was kayak support, not participant) and that was enough to convince me that they will be good for me. I was just interested in any update from the discussions of a couple of years ago, hopefully without igniting more unrest in slowtwitchia!
I started at what I use normally on the road 172.5 in a shoe I use with a lift. Then I did a shoe with no lift at 172, no lift at 170 now downto ~ no lift at 168. I’m going to keep dropping lower see how low I can go & then be come more unbalanced in the opposite way. So this is an experiment in progress so far it doesn’t seem to be a fluke. Speed slightly up, time dropped & watts are slightly up as well, rpm may have dropped along with spin values. Hr not much of a change nor with the power splits L/R. May be a bit with ATA. But looking just at averages can be misleading. Taking in the min & max for each parameter the spread between the min & max decreased which is a good thing. Suggest that I might be getting the pedal around smoother.
I need to do this a bunch of more times. Then there’s always the changing dynamic - I’m getting better at using PC as I go along.
I also start out each week using a ride on the CT for that week that I saved against myself from same time last winter Thus far for 5 weeks using 5 different rides that I ride multiple twith exactly the same bike on the CT (an extra now CT only bike), my times have dropped just using the PC over the 170’s I had on there. Then with this new expt I’m dropping significanltly again.
Barb
Bump up in hope of a response from Tom!
Hi There, thanks for the question atomic916.
I don’t still use them but I wish I did. The pair I used belonged to a buddy of mine (Frankie Andreu) and I think there was another pair around her too. Once everyone found out (and saw) they worked they kind of… disappeared.
Everyone wanted theirs back.
They *really *helped my running. I can’t explain why. I was faster on the run very quickly and running felt easier. It was as though I was doing run training and bike training simultaneously. Riding benefitted both and my training did briefly vault ahead. It’s worth pointing out that there is no “payola” between me and whoever it is that sells these things.
My ability to turn a faster cadence improved significantly too, and I could pedal at 105 R.P.M.s to beat the band. Now, I am not one of those people on the “higher cadence is better” bandwagon. I am not. I think everyone has their own optimal cadence dictated by a host of things, some quantifiable, some not. I happen to think my optimal cadence resides around 88 R.P.M. based on the numbers I see from three (now four…) years of Computrainer data.
I don’t see the point to the unwinnable debates over equipment like Powercranks. For me, I had a training and performance benefit. I mean, I rode my bike faster and easier, improved one specific skill (ability to ride at higher cadences, if I ever needed that skill) and I really had a better time run and went faster. Yeah, they are expensive, but I think they worked. If you have the money, they are worth it IMO.
Thank you very much Tom, I’ve pretty much known since I demo’d them that I would end up with a pair, It’s just been a matter of when. It’s always good to hear impressions from those with a valued input.
Thanks for asking. The fella that sells them is a really nice guy too and very helpful. Good luck to you Sir.
