Parsnip and mustard collard. How to cook?
Ok, I am in week 2 of my detox, running out of ideas for veggies here. so i randomly brought 2 new veggies tonight, parsnip and mustard coolard green. any ideas what to do with these? Right now I am suppose to steam the veggies i eat, but i wouldn’t mind ideas for the futur anyway. are you guy getting tired of my cooking posts? I am still making those sweet potatoes, great ideas:-)
Why would you want to do this to yourself?
why not? I am trying to eat healthier! someone on ST will know… so many people on paleo and most people eat healthy right?
those veggies you mention are too low on the food chain for me. ugh! :wink:
Parsnips aren’t my favorite, but they are OK fried. Guess that’s not what you are looking for.
Greens are good added to soups or pasta sauce. Or steam them and toss with a bit of salt, garlic, cracked pepper and balsamic vinegar.
Have you tried http://www.recipesource.com/?
clm
rinse them really well. if you HAVE to steam them (which i wouldn’t recommend for these, but if you have to you have to) do this:
-get water near boil
-drop them in steamer basket
-steam until wilted
-lightly sea salt with black pepper
-if you are allowed a little olive oil or any kind of dressing, put some on there
my PREFERRED way to make them is this:
-slice up onion
-get pan hot
-add olive oil. tablespoon maybe and a drop or two of canola oil
-drop in onion, sautee until they are translucent and soft. maybe 5-8 minutes.
-once onion is transulucent, drop in a whole bunch of greens in pan. load it up good.
-they will wilt, use tongs to “stir” or a giant fork
-once they are all wilted and hot, season with salt and pepper
i LOVE mustard green. they are delicious. if you like a smokey meat flavor do this:
-dice up smoked bacon, or pancetta
-slice up onion
-get pan hot.
-put bacon or pancetta (or both!) in, and sweat out the fat
-remove bacon
-add onion, small amount of canola oil to the bacon fat
-let it go, sear onion
-add greens
-be careful with salt, bacon will already be salty. use pepper or red chili flakes, whatever
-plate it up. and you’re good to go!
thanks KC. I appreciate the details as this is like cooking 101 for me:-)once i can eat more stuff i will try pan frying them in olive oil:-)
the thing about greens is that you don’t have to do a ton to them to make them good.
mustard green, collard greens, all of that is so good. and basically it’s the same principle:
get pan hot, sautee an onion (if you like onion like me), drop in the green and let them wilt down.
you can add spinach to this and have alot of different greens together.
this whole thing takes less than 10 minutes. i like to put a piece of salmon, crab cake, or other fish on top of a bed of greens. it is delicious.
you should be able to steam these the same way you would do other vegetables. it will happen quick, once they’re all wilted they are done.
also–even a little water in a pan, instead of oil would work. get the pan and water hot, drop in the greens, they’ll wilt up and you’re done.
they wilt down to nothing, so load the pan up. or do it in 2 batches.
if you’re allowed garlic, you can put a little more water in the pan, add garlic (or onion or both), let it boil so the garlic (or onion or both) softens up in texture and flavor, once the garlic (onion or both) is translucent, then put in your greens. this actually would be quite good!
just to be clear, there doesn’t need to be a ton of water in the pan. similar if you would have oil, that’s about the same amount of water you need–a little more if you want to have garlic (onion or both) in the greens, so that there is enough water to boil with garlic (onion or both) for a few moments. essentially, the water in the hot pan could replace the fat in the olive oil.
if you’re allowed lemon, you could even squeeze some on top of the greens when they’re done. it’s good!
i do not recommend eating greens raw. from my experience, it would require a strong stomach…
thanks jo:-) I will do the lemon. what does “wilted” mean? I don’t know that word!
I’m not sure i would want to be in here house after she ate that stuff, if you know what I mean.
I’ll throw in an eye-talian slant…
You can make parsnips “risotto” style. They must be diced into small, uniform pieces, slightly larger than rice. Saute onion in olive oil, until golden. Add parsnips and cook until they begin to carmelize, a few minutes. Add a ladel of stock (vegetable, chicken) and cook, stirring continuously. Once stock is absorbed, taste for “doneness”. Add more stock and repeat as necessary. When finished, add parmigiano cheese, and a tablespoon of butter if you’re feeling frisky. Sprinkle with some chopped parsley and she’s done.
The Italian way with any green is simple. Good olive oil in a pan. As much garlic as you want, sliced thin and sauted until pale yellow. Red pepper flakes to taste. Saute the greens with only a bit of water left on the leaves - in other words, clean and spin the greens - until wilted. Salt to taste. If you want to get fancy, you can sprinkle some bread crumbs over before serving.
greens that are cooked become wilted, they are soft and cooked through. wilted is also what happens if you don’t water a plant–the plants droops and is limp. wilted is without water or limp, in other words. in the summer if you have a tree that looks droopy, you could say “the tree is wilting”.
http://www.5aday.gov/month/greens.html
this will give you more ideas for greens. :slight_smile:
BTW, once the greens are cooked through, and are wilted, the cell wall of the plant is changed. and i’ve read that it is more digestable to eat greens this way, and will be less likely to cause gas or other stomach problems. (that’s why i said i do not recommend eating raw greens, as doing so is very hard on the stomach)
Ahh, there is definitely a cultural divide when it comes to cooking mustard greens and collard greens.
I am a southerner and african-amercian and we would never, ever saute greens in oil! I also mix my mustard greens with turnip greens. Collards are a little too strong for me.
You need a ham hock, some fatback (salt pork), a big pot and some water, red pepper. Cook for at least an hour (really for the collards) Then you need some cornbread.
I only eat like this on special occasions, too much fat for me now.
Saute, I got a good laugh.
INGREDIENTS: 4 to 4 1/2 pounds turnip greens 1 pound salt pork, rinsed and diced 1 1/2 cups water 1 cup finely chopped onion 1/2 teaspoon pepper 1 teaspoon sugar, optional a dash of crushed red pepper, optional PREPARATION: Cut off and discard tough stems and discolored leaves from greens. Wash greens thoroughly and drain well. Cook salt pork in a large pot or Dutch oven over medium heat until crisp and brown. Add the turnip greens, water, onion, sugar, pepper, and crushed red pepper; bring to a boil. Reduce heat, cover, and simmer 40 to 45 minutes or until greens are tender. Taste and adjust seasonings. Serve with vinegar or pepper sauce and cornbread.
Serves 6.
kitty thanks for the website, that’s nice. vols, I appreciate cultural differences! Not sure i would cook it with that much fat, but it’s nice to have options:-)
that’s how my mom does it…except she calls it sal belly instead of fatback. (what can i say, it’s appalachia. you should have seen the butcher’s face when i moved to Cincinnati and asked for sal belly. he said, “girl, where are you from!?”. )
i still do greenbeans with salt pork. boiled soft (for hours) with salt pork, maybe some thin sliced onion. it’s the only way.
I don’t know why anyone posts for recipes on a general thread instead of just PMing you, KC. Seems to me you could write a new recipe book every month for ever! Is there anything you can’t cook? All your recipes sound so good without the hint of a nod to low fat PC correctness.
Good on ya, gal!
i still do greenbeans with salt pork. boiled soft (for hours) with salt pork, maybe some thin sliced onion. it’s the only way.<<
That’s exactly how my mom would make them!
well, that’s a nice thing to say!
you know what’s lame? i buy cookbooks just to read them. (even though i end up not making most of the stuff i dog-ear to try out, i’ve convinced myself it’s ok to continue to buy cookbooks because somehow along the way whatever i learn ends up in the food. hey, we have to justify things somehow, right?)
i haven’t had much confidence in my cooking mojo over the last year or so; my mom says it’s just a rut. but lately, it’s gotten better around here given that i’ve tried some new stuff.
this past weekend i made fried oyseter po boys; walnut crusted walleye; several vegetable sautees with eggs for breakfast; crab cakes with spinach; and a soup.
one of the egg & vegetable breakfasts was really good. it was a small bed of seared shitaki/baby bella mushrooms/onions with eggs over easy on top. i’ve got some very good hard white cheese, and grated that on the eggs…it was really good.
most of the stuff is simple, but good. good ingredients, that’s the key.
