Painting disc/trispoke
If you were going to paint a disc, renn, and a hed 3, what kind of paint would you use? I am looking to go all white. I would like to do it myself, but reccomendations for professional jobs would be cool too.
Also, is anyone aware of a way to run a 575 on the track? Frank, are you listening? A 400$ track disc would be awesome.
Thanks
automotive paint if that helps, I used Createx auto air on a carbon Kestrel but I don’t have to much experience with other paints. I liked the Createx as it’s water based and non-toxic. Light sanding for surface prep, quick alchohol wipe, then lay down a primer coat followed by the white. You may have to heat set the paint but I’ve pulled that off with a heat gun before. You’ll probably need someone to spray the clear coat for you if you want that.
Or you could just be like my old lbs, rough it up with sand-paper, whip out the spray can and let er rip. It ends up pertty decent but scratches easy.
Last option, shoot me an email at Tai@taigraphx.com and I could send you a pic or two of the vinyl decal option. You could get the whole disk white with a big decal but the tri-spoke might be tougher. You could do some pretty cool designs though.
