Hey folks - I’ve got a velo safe II made by Tri All 3 sports (secondhand) and need to get two bikes in for shipping. Made it to Chi-town with both bikes in August but it was a squeeze, wondering if there is a ‘preferred’ way to pack these things? I’d like to get one road bike and one tri-bike into it along with both sets of wheels. Any help (including pictures for comparison) would be awesome. I know with all the travel and racing that this board does someone can help me out.
Packing 2 bikes into a VeloSafe II is tricky but very doable. Get a lot of zip ties, and some bubble wrap or foam pipe insulation to protect the frames. The trick is to have nothing floating around in the case.
I remove both pedals, although they say you can leave one on. I remove the handle/base bars and zip tie them to the (bubble wrapped) frame so they don’t flop around. I usually just pack the pedals and saddles w/seatposts in my suitcase, but you can put them in the case if you wrap them up and strap them too something.
I’ve done it a few times, but yes, it can be a little tricky. It totally depends on the types of handlebars/aerobars and how much you can move them around with how they are cabled, and the kinds of wheels you are carrying. It might be really hard to pack in two discs for example. The last time I did it I made sure to wrap the tubes in pipe insulation and zip ties to protect them, and then used ripped up pieces of a cardboard to keep the axles and handlebars from potentially rubbing against anything. Just take your time and you’ll get it to work eventually.
