That’s the adjustment screw for the set screws in the rear dropout. Yours is obviously defective and we should trade bikes.
The “water bottle” is an aero fairing and not actually meant to be used as a water bottle.
Whoa! I cant believe you would get a bike like that and not know what the adjuster thingees were, it was an integral part of the marketing material!!! With the exception of winning lotto or something, I wont be getting one, but the retention of the bottle is an issue in my opinion - it sounds as if it only happens when filled, which as it seems to be a fairing first and foremost is sorta ok, but what will happen if you chop the top or use the bento box version when filled with a couple of co2s, tube(? will it fit) etc. Will it be sufficiently heavy to also cause it to eject?
Good luck with the bike regardless, may your bike splits improve ![]()
