P3-SL vs. P3C seatpost & setback question
I’m setting up a P3C (54) to match my old P3SL (55) configuration. On the P3-SL, I used the seatpost turned forward, but slammed the saddle almost all the way back to achieve a 0cm seat-bb offset. To get this offset on the P3C, I have to use the forward hole, but I also have to push the saddle almost all the way forward too.
The P3C will work for me, but I’m surprised by this. The most forward seat position possible on the P3-SL is maybe 3-4 cm in front of the BB, on the P3C it’s only about 1cm. I’d think it would be the opposite, since the P3C is nomially the smaller frame. Anyone else notice this? What gives?
–jens
Lets see a pic when you are finished. :slight_smile:
What’s your saddle height?
73.2 cm.
-jens
So basically you can’t ride steeper than 78deg. Interesting.
And hey, I can ride your bike!
Admire it, fawn over it, drool over it – Yes. Ride it – no! ;-).
I just did the actual measurement with a plumb bob. With the seat slammed all the way forward on the rail, the tip is only 1cm in front of the BB. I feel like I must be getting something wrong. The top tube doesn’t slope at all on these does it?
-jens
jens,
how tall are you?
jens,
how tall are you?
5’10
not to hijack the thread but how do you like your p3sl? there’s one for sale for $2999 that i’m seriously thinking about. i’m 5’11" and it’s a 55 so i don’t know if it will fit though.
On my 56cm P3C I can get 3cm in front of the BB with a Arione.
Awesome bike. I can’t tell you about sizing. That’s dependent on a lot more than your height.
-jens
That would square pretty much with my measurement – the Arione has an extra 2 cm, right?
-jens
I thought most of Airone’s 3cm extra length was rearward.
From Tom D’s site:
When I initially examined the Arione in the Las Vegas Desert at the Interbike Dirt Demo 2003 I though the rearward most 2 cm of the saddle was a waste, merely cosmetic. In actually using the saddle I discovered I was wrong. It is very useful. The Arione opens up the “fit band” so that a rider has more options as to where they can position their pelvis over the bottom bracket. This 30 cm (3 cm additional over previous saddles) range of motion provides substantial enhanced capability for the rider to employ new pedaling geometries. This also included being able to effectively raise and lower your saddle as you slide forward and backward on the saddle itself. The farther back you position yourself, effectively the higher you are. The farther forward you slide the lower you are effectively, positioned more vertically over the bottom bracket and compressing the pedal stroke. This affords the cyclist a wide range of pedaling styles not as available of traditional saddle designs.
http://www.bikesportmichigan.com/reviews/arione/arione-w-dots.jpg
This should be correct. The laid back P3SL carbon post when flipped forward puts you at a further forward starting point than the P3C forward hole. Why not just use the P3SL post (or is thie not usable in the P3C) ?
The P3C seatmast is about twice as wide (front to back) as the P3-SL’s. It’s really not an issue for me, since I only need a 0 setback. I was just surprised and curious to discover this.
– jens
