P2SL worth the upgrade from the Dual?
I was quoted $2K for the P2 and $1.5K for the Dual from my LBS. For a middle of the pack racer doing their first Half this summer, is the $500 upgrade worth it? Or should that $500 be better off going towards something else (nice shoes, new pedals, etc.).
Also, the wheelset that comes stock on the Dual and P2 are the Shimano R-550 or the Velomax Vista depending on the Ultegra/DA setup for the Dual, or the Shimano R-500 Aero for the P2. I recently got a new custom made wheelset from Colorado Cyclist (Open/Pro Mavic with the Ultegra hubset - SHIMANO Ultegra 6600 10 speed custom wheelset). Are the wheels I have from CC comparable or better than either of the stock sets that come with the Dual or P2?
I don’t know about the wheels, but the common advice around here on the Dual vs P2SL is that the extra $500 for the P2SL doesn’t buy you much. I will probably be purchasing the Dura Ace Dual, but I’ll also try out the P2SL and the P2C. If the other bikes ride much better, which I’m not expecting them to, I will purchase the Dual and use the money savings to buy some race wheels.
I don’t think there’s anyone that will tell you that you’ll be noticeably faster on the P2, if that’s what you’re asking. To me, the only tangible benefit of the P2 over the Dual is for the anodized finish (is that still the case?), which is more durable than the painted finish on the Dual. Although, I have no complaints about the paint on my Dual, others do. So, if it were me (and it was in June), I’d go with the Dual and spend the extra money elsewhere (like a wheel cover for the back wheel, an aero helmet & whatever else you may need).
I don’t have any experience with the other wheelsets you mentioned, but I don’t really have any complaints about the Vistas on my bike. I expect that they’re a bit more aero than the Open Pro rims, and the hubs seem very smooth to me.
Steve
Your wheels are excellent training wheels, at least as good as the stock wheels on the Dual or P2SL (assuming they are built well). Get the Dual, spend the extra bucks on a wheel upgrade, aero helmet, or something like that.
I like the lowered seat stays (maybe slightly more comfortable… maybe) and the nicer seat tube with the cut out. Some say it is more aero, I know it is nicer looking.
So
you would train on my wheels and use the stock wheels as race wheels?
When you say upgrade a wheel, would you upgrade the rear over the front
and just continue using the stock front with a disc rear?
IMHO, I would not upgrade to the P2SL. The difference in the frame is minimal and not worth $500. You should get a true set of race wheels, or a wheel cover with the extra money. If you wanted to spend much more, you would feel a difference between the Dual and the P2C.
As far as your wheels, the R550’s are an entry level training wheel. They are heavy, but bombproof. The other wheels that you have are an upgrade but would still not be considered a “race” wheel by most. If you dont want to spend $$$ on a set of aero race wheels with deep cross sections, I would go with a wheel cover and use your Mavics to race. Kill the R 550’s on training rides where you wont have to worry about beating on them.
$500 can buy some other nice gadgets also, upgrade bike comp, HR Monitor, Helmet, shoes and/or pedals.
I’d try to buy either bike without wheels or with racing wheels rather than the Cervelo spec wheels. Yours are better training wheels and none are great as racing wheels.
One thing I prefer about the Dual is the crank. Although the Gossamer is cheaper, its attachment mechanism is similar to that used by Shimano - a pinch bolt on the non-drive arm - whereas the FSA carbon cranks rely on the crank bolt itself to hold the whole mechanism together.
I have a P2SL and it seems like a reasonable bike, although not as comfortable as my last TT/tri bike, a QR vintage 1990. If you’re a mid-pack rider, the Dual is probably all the bike you need unless you want the anodized finish. (And no, I don’t have the FSA carbon crank because I use an SRM with Campy bottom bracket.)
i have a p2sl and it is sweet but not very different than the dual. Get the dual. Sell the wheels that come with it for 2 hundred dollars. now you’ve got 700 to work with. get an aero helmet and a rear disc cover. Get a flashpoint 60 front or other aero wheel and you are ready to rock!
Dan
www.aiatriathlon.com
When you guys say to get a rear wheel cover, what is that and can it be used with the wheels I have?
you can get it on wheelbuilder.com . It’s called a “CH aero cover” .
Just put it over your rear training wheel. Requires removing the cassette.
Dan
$200 for the Shimano wheels, eh? What about the Velomax Vista’s which come standard with the Dura Ace Dual?
maybe more. I am not an expert. You could look on ebay and then the classifieds here to get a good idea. Not much reason to keep those wheels though.
Dan
Only real differences are dropouts, cutout and appearance. You will probably find the vertical dropouts of the dual easier to use and the cutout is a minor benefit.
Perhaps talk to the store about buying the bike sans wheels - you already have excellent training wheels. Buy a wheel cover and decide whether you want to get a front race wheel - something like a flashpoint 40 or 60. This way you would have a great bike with both training and race wheels for less than the cost of the p2sl.
Having shoes that support your feet and pedals that engage securely is also important - buying the bike without wheels would help towards that.
Are wheel covers really worth it? Would I just throw it on over my Mavic rear that I’ll be using for training? What’s a pretty good yet reasonably priced front race wheel?
For $65. a wheel cover is the most aero bang for buck that you can buy.
Where can you get a good aero cover? Are they easy to install?
cover definitely worth it. Your training wheels have good hubs, put on the cover and nice tyres for race day and you’re set.
Front wheels:
http://www.excelsports.com/new.asp?page=8&description=Flashpoint+60+Front+Wheel&vendorCode=ZIPP&major=1&minor=24
Hed have some nice options.
For a cheaper but still fast option look for 30mm alloy rims with low spoke count - could build a wheel like that for a couple of hundred.
Best to sit down with your LBS and talk about this plan - say that you’d like to get a front race wheel, a wheel cover, shoes and pedals and swap back the stock wheels - see what they can come up with. If they can’t get all the stuff then you’ll have to go to the net but you never know - they may be able to make the whole process much easier.
Wheelbuilder.com
The are easy to install and custom cut to your make of rear wheel.
Awesome, thanks for all the replies everyone. I will try to to see if my LBS will sell me the Dual wihtout the wheelset and see how much they’ll knock off. Anyone have an idea of whats reasonable there?
