P2C vs. P3 carbon
I am looking at both a used 2008 P2C sz 48cm as well as a 2008 P3 carbon same size frame. Componets are both Dur-ace. What are the main differences between the two bikes. Same price for both. I would appreciate any comments. Thanks.
If it’s the same price, get the P3!
I believe the P3 has a slightly lower stack height I believe, and the frame is a bit more aerodynamic. Other than that they’re pretty similar if they both are spec’d equally…
At that size they have the exact same stack and reach so they would fit they same. P3 is more aero, a touch lighter and stiffer. If everything is identical I’d go with the P3.
