Picked up a P2 SL frameset yesterday. Built it up last night. However, there’s no insert where the rear brake cable exits the top tube. I assume there should be an insert here, so that I only need to run housing from the insert to the rear brake, but I wanted to make sure there’s not some secret Cervelo cable routing instructions of which I’m unaware.
Input?
Input?
This (ICS) should have came with the frame.
https://customercare.cervelo.com/estore/viewdetails.aspx?id=10&page=1
Cheers!
Trevor
Cervelo typically ships the frames with the rear brake cable guide (cable exit from the top tube) taped to the frame with a loop or two of masking tape. Give them a ring to get another one.
