i would like to know what are the measurment of the trek tt frame (size medium)…top tube and what is the lowest possible height for the saddle mesure from bb to saddle(seatpost completly in)…anyone can help… i m 5.9 and 32 inseam and wounder if the medium size is a good fit
a small is probably a better fit. i rode both med and small in the equinox and i am 5’10 with same inseem. if i had bought a trek i would have gotten a small.
I have to agree. I’m 5’8.5" w/31" inseam. I was fitted on a small. Might not be able to get the seat low enough, and I’m also using a 90mm stem. I’m positioned in more typical road position w/saddle 5CM behind the bb though.
The Trek TT fits a bit small (I’m 6’0" and ride a M) but here are the mesurements you asked for:
Top Tube - center seat tube to center of head tube - 56cm
Lowest seat hight possible - center of cranks to top of seat - just under 74cm (738 mm)
The minimum saddle height also depends on what saddle you’re using. An Arione tri has much more “height” (distance from rails to top of saddle) than an SLR.
Can’t help you on the measurements, but I’m sure others will.
I’m same height/inseam as you & have the small tt bike.
