Owners of 1up trainers or blackburn ultra's HELP I am either an idiot or lostr
or both. I have had a blackburn fluid. It has been great. Had to get another trainer due to my wife wanting a bike. I now have a Blackburn ultra. Designed by 1up and seems to be the same machine. I set it up and try to ride. I seem to get a lot of slip. So I tighten it up and now my tire squeals and i will never get out of the small chainring. I loosen to no tire noise and tons of slip. I try to find a balance of not to much tire noise and still not to much slip. Seems still hard for the gear I am in. I am not a strong biker. Avg speed for outdoors 17ish, 6 to 6:25 IM.
Due to 1ups easier rollout, is it just accentuating my poor pedal technique, and thats causing the slip? It seems after an hr the slip was not as bad. Or am I just weak biker and thats a power issue? If thats the case, how do I stop the squeaking. Plaese help here Thanks Kenney
Are you using Continental tyres?
No. Old used Michelin Pro Race tires. Save old tires for trianers. Thanks…Why would tires make effort seem harder? Or are they known for squealing. I am really wondering if my pedalling technique is just so bad.
bump for the busier week crowd.
I only had slip on my 1up when I first set it up. I hadn’t tightened the resistance unit tight enough. I really had to crank down on it. Haven’t had any trouble since then (four months ago). No tire squeak either.
I’d call 1up (or Blackburn) if it still gives you trouble and you’ve tightened the unit as much as possible.
Boy, that sounds familiar. I have a 12-year-old Blackburn mag TrakStand and likewise use old Michelins as my trainer tires. I set the pressure so that it doesn’t slip too badly when I’m accelerating, which makes it not slip at all once I’m up to speed and it squeaks until the tire warms up. Well, I assume it’s temperature related, I never checked, I just force it to slip a lot with a jerky pedaling form (standing or mashing the downstroke) for a few minutes and then it stops complaining for the rest of the ride.
I just bought an ultra last week and rode it for the first time Saturday. I had to fiddle with it (tighten) for the tire not to slip, but I’m with you: that thing is for sure hard to turn over. There was no way I was getting on the big ring…I could barely get on the bottom of the cog in the 39. I wish this thing were adjustable, because I bought it in order to do high cadence drills.
Have you cleaned off the tire? Some trainers, CompuTrainers for example, suggest wiping the tire clean using a rag and some isopropyl alcohol…
I have the blackburn fluid, it makes noise when the tire is not inflated properly, 100-120 psi. I also use an old Michelin. Also i crank the resistence know .5 turn after the tire makes contact with the roller.
Did they give you the 3 bearings to make it harder…shit, gotta be superman. I am still wondering if the slip is to terrible pedaling tecnique. If I loosen enough for to stop the squeek, again I seem to balance out than just mashing. As one poster said he had to really crank it down. It does not seem you would have to clamp down tighter than other trainers. Thanks for the reply
