Overheating Rims
Looking for some feedback on overheating my wheels braking. I was on my second loop descent into Keene for IMLP, and as I hit the second half of the descent I started to brake. I first pulled on my rear, and then applied the front. I think I might have just held the front down with progressively more force instead of my usual pulsating style of braking due to wanting to scrub speed off in a hurry (Still a bit skiddish on downhills following last November’s accident - broke both hinges in my jaw, split chin, cheekbone, and shattered 14 teeth). I heard a crazy noise, looked down, and my front tire was completely flat with about 4 inches of rim tape out of the wheel. First time I’ve ever had a flat at that type of speed, and needless to say, it scared the shit out of me. I managed to maintain control, unclipped my left and essentially Fred Flinstone’d myself to a stop. When I pulled my front wheel off my bike, it was scortching hot. I made the horrible mistake of pulling my two tubes I was carrying out, and accidently set my wheel on top of them. The rim was so hot that it melted the tubes enough that they blew when inflated (there was nothing in my tire that caused them to blow, and the tire was still intact). The SAG vehicle had no extra 650 stuff, so it was the end of my race.
I’ve entered Ironman Florida, so no major descents like Keene in the near future, but I’m curious as to if this is a semi-common thing when decellerating like I did. Also, I thought the rim tape coming out was a very strange sight - is this normal? Is this preventable?
Additional info: on a 48 p2c, ran Zipp 404 clinchers w/pro 3’s. 5’2, 127lbs according to Saturday’s weigh in.
Had you previously done many rides on the wheels as they were on race day or had you just changed the tube or rim tape?
Rims do get insanely hot on downhills, especially if you’re not pumping the brakes which seems to help.
Freaking what? I am sorry man. I have raced for years in the mountains, IMLP a time or nine. I have crashed at 70mph in Springs…never ever had I heard of ANYONE anywhere melting their tires. I call BULLSHIT on this one. You wanted a way out and found it. Why is it that YOU had an issue that no one in any pro tour has ever had? If this was an issue, it would not be you walking on the water of this issue…someone long before you would have had the issue.
he didn’t say he melted his tires
http://cache0.techcrunch.com/wp-content/uploads/2009/07/bullshit.jpg
Bullshit.
may be
but those are tubes not tires =)
id the blowout messed up his rimtape
I wager I know what made the tubes blow when inflated.
Install error? ID 10 T error? newbie mistake? No matter what…no way to melt tubes…I have ridden my brakes HARD on 70mph decents…never ever melted a freaking tube. Then add to that the fact that Alu is going to shed that heat fast even if the rim was warm.
yeah, that is my guess
Install error?
I could envision a disc brake on a mountain bike getting hot enough to melt a hole in a tube right after a long descent (in one of my brighter moves I touched a scorching hot disc right after a descent and burned my hand badly enough to blister it), but a rim brake? Not going to happen.
Given his description of the rim tape hanging out from the flat, I’m going to say that’s the culprit.
Now who needs to have the BS flag thrown at them? The only way you could hit 70 mph on a bike on a descent is if Phil Ligget and Paul Sherwin were commentating on your race.
Chad
Easy killer. A few things.
1 - I’m a girl, not a guy. :slight_smile:
2 - I didn’t melt the TIRE, nor did I mean the tube that was INSIDE the tire at the time of a flat.
When the OUTSIDE of the rim came in contact with my spare tubes, I believe the heat damaged them, because after checking my tire for any type of glass or anything poking through the tire, they blew upon inflation. The damage to the new tubes did not appear to be a pinch flat or from anything inside the tire based on the way they ruptured. Again, these were my SPARE tubes I was looking at, so I assume that placing the hot rim on top of them damaged the integrity of the tube in some way. I could be completely wrong, its just what I observed.
I simply wanted to know if there’s a way to better handle braking if needed on a steep descent, and wondered why my rim tape came out.
And, no, I didn’t want a way out. I’ve had a shitty, shitty year following my own accident resulting in my jaw wired shut for 5 weeks, and then my dad dying from brain trauma 3 weeks later. Sorry, the idea of crashing still shakes me up since my dad died from it, so I don’t go full speed on the downhills. I wanted to complete this race more than anything, and balled my eyes out for a good portion of the next 8 hours.
Pretty sure it’s a chick you’re yelling at, R10C.
I put the rim tape back into the wheel once I dismantled everything… it was still sticky and the spokes were covered.
I suppose there was a bad description there - I wasn’t saying the tubes were melted once back inside the tire. :slight_smile:
And, I agree - if I had said that the tubes (or for that matter the tire) melted while mounted, I’d call bullshit too. But, that is far from what I meant.
And you are still alive** **,you are a saint, glory be . ;-0
I just did a climb up Mt. Burke in VT which had some continuous 20% stretches and the climb description on northeastcycling.com states:
“However, great care must be taken on the descent. Due to extreme steepness and frequent sharp switchbacks, heavy continuous breaking is required. Even my MTB disk brakes faded on me one time coming down. This has never happened before riding off-road. Most riders would do well to reduce tire pressure about about 10-15% before beginning the descent and stop half way down to let rims cool.”
I didn’t want to let any air out, so I stopped 3 times over the 3 mile descent, and each time my rims were hot enough that I couldn’t hold my hand against them without the heat being painful.
R10C, I think the rims cool pretty quickly if you can lay off the brakes for even a short while at high speeds, I doubt the pro tour riders are ever on the brakes continuously for more than a minute.
You did not say anything about the brake pads.With your report of the rims and their temp. your pads would have melted.The heat from braking is transfered in energy (heat) to the pads first.
I roughed up my pads with a large grit nail file prior to the race… and they currently have that super silky film over them again. They are the dura-ace pads, if that matters?
700 tube would have worked since the support had no 650’s
bummer though way to hang in on with the flat always my fear.
CDW…many many 70mph hills here (in the US). Out of Co springs and on and on…even the Keene Hill is worth well over 60 if one has the gears and balls.
