Oval Concepts Brake Levers
Does anyone know if you can use the oval concepts aero brake levers with the vision base bar? Thanks
Hey Matts
Go with the Vision levers there much cooler and more aero, I had the off brand version of the Oval levers and I switched them for the Visions and I like them better. But can you use the Oval’s with the Visions bars? I have Oval A700 bar’s that have the same ID as the Vision bars and I had to grind down the lever insert to get it to fit. So yes you can but you have to do some grinding.
Dan…
