Out of breath on the Tri Bike Only
I have been wondering why it seems that I get short of breath on the tri bike only, (not on the road bike) I had it fit at the local B S, and thinking about getting fit at another LBS. The only thing I can think of for this is maybe my big stomach takeing up to much space. Any sugestions? Thanks.
You may need some spacers and/or a riser stem.
During a bike fit the fitter raised my position by 8cm!! My back only came up 2cm. The problem was that I was rounding my shoulders to reach the elbow pads instead of flattening my back. This “rounding” actually prohibited breathing. Not saying this is what your problem is but you may try going “higher” instead of the ST approved “lower”. I was faster in the “higher” position because I was able to breath easier.
BTW - Beofre that fitting was reach was 17cm…he raised me to 10cm drop. I’ve now returned to an 18cm drop as I moved more forward and became more flexible. Moving forward opened the torso to thigh angle so I can still breath.
You lose some power riding aero but make up for it with the aero position being more streamlined…it takes months to adjust to the position, different muscle emphasis, you are more crouched on the bike, harder to breathe…I found it a big adjustment…it could be a fit issue, but you can’t compare road and tri geometry, it feels different in terms of power…
is it possible your bars are too narrow? maybe squeezing too much into a small area compared to the wider hand and elbow position in the drop bars on your road bike
good luck
Barry
