OT: Riddles
I’m doing a local fun adventure-type race with my daughter on Father’s day, and if I answer the following puzzlers correctly we get a time bonus (I think). It’s no big deal, we’re just doing it for fun, but this will give you guys a chance to show how smart you are! I think I know the answers to questions 2 and 3, but tell me what you guys think:
**Question 1. You want to travel 100 miles on a Big Wheel and you have 2 spare tires. You must use all 5 tires equally and have equal mileage on each of the 5 tires at the end of the trip. You can only use 3 tires at a time, so you’ll have to change tires during the trip. At the end of your trip, how many miles will each tire have been used? (For the purpose of this question - all tires/wheels are the same size) ** ****
**Question ****2. You have twelve 12-packs of bottled green tea. All the bottles contain 12 oz’s of tea except for one of the 12-packs, which has only 11 oz’s in each bottle. You’re given a scale with low batteries and it can only take 1 measurement. How do you determine which 12-pack is short? ****(You can’t determine the answer by looking at the bottles and you must use the scale to find the answer. You can separate the bottles in the 12-packs, but can’t open the bottles. Assume that the weight of the glass bottle is zero). ** ****
**Question ****3. Solve the ‘Wordable’ below. **
********0
M.D.
Ph.D
L.L.D. ****(example: Cycle Cycle Cycle = tricycle)
Sorry for the three posts… for some reason I had a problem getting this on one post.
60 miles.
3 wheels at a time x 100 divided by 5 = 60 miles each.
Is the “0” part of the 3rd puzzle?
take 1 in the first, 2 in the second,…,12 in the last one.
so you have 78 bottles. if all were 12oz, the weight would be 78x12.
if the first pack is lighter the weight will be 78x12 - 1
if in the second 78x12 - 2
etc.
wtf do I answer that?;
Yes…
Wow, that is fricking smart. I was just going to read the labels.
I think I figured out Question 2
If you put split up each 12 pack into a group of 7 and 5, then you could make up 6 12 packs containing 3 12packs of 5 and 3 12 packs of 7. So now you have 2 groups of 6 12packs. Put these 2 groups on the scale… the lighter side is the side with the 2 extra bottles that weigh less…
…done !!
{EDIT}…crap… I thought it was a balancing type of scale… not a digital scale… crap… I thought my answer rocked !!
then it’s “3 degrees below zero”.
I thought reading the labels was a lot smarter :slight_smile:
No fair. This is a leisure-time combinatorics problem for you. But thanks, I forgot the answer.
Wow (and I mean that sincerely). Maybe my guidance counsellor was right. Learning math does give you the tools to solve all problems.
Does this only work if you assume 12 ounces is a measure of weight rather than volume?
Looking at a bottle of 12 oz. of green tea, I would think this meant twelve “fluid” ounces in volume rather than the “avoirdupois” ounce for weight measurement. Since 12 fluid ounces of green tea would be a bit more than 12 ounces in weight (something like 12.5 based on the water equivalent), would you need to know this exact weight first in order to solve your equation?
Ahh Friday…
Q2: Take 1 bottle from pack 1, 2 from pack 2, and 3 from pack 3. Weigh all 6 bottles.
Total = 69 - 3rd pack is light
Total = 70 - 2nd pack is light
Total = 71 - 1st pack is light
actually it works for weight not necessarly for volume…because then the liquids in each bottle may be different hence a different weight, and no possible conclusion could be drawn
your answer is the right one - and would get you the answer you are looking for
I like the answer of - “go buy some new batteries”
If you know the density of the green tea, then you could determine the weight from the volume, assuming that each bottle is the same.
Jeromy
yes but then several combinations of bottles and different densities could mess up your results as several linear combinations could yield the same result. So you wouldn’t be able to answer.
Ya, you have to assume that all of the bottles came from the same batch.
Jeromy
