OT - GSM phone or alternative
hi,
I have to travel to South Africa (from the states) for work, and last time I went, I didn’t have a phone - huge hassle. Does anyone have experience with using GSM? I don’t know much about it at all. Any other alternatives good for being reachable when you’re out of the country?
thanks!
~geek
I love it (T-mo), GSM is basically the cell phone standard anywhere else but the US–though it is rapidly filling in around the US. Very convenient if you do a lot of international traveling.
Assuming South Africa has GSM coverage (and your phone is compatible with the particular network), you just need to purchase a pre-paid SIM, pop it in, and GO. You’ll have a new phone number with that SIM, of course.
More on network compatibility…there are different GSM frequencies-- 800/900/1800/1900 Mhz. Not all companies/countries operate on the same frequency. You’ll just need to make sure the phone you purchase is compatible with the network you intend to use. Shouldn’t be a problem though, as most GSM phones come “tri-band” (900/1800/1900 seems to be the most popular combination). 1900mhz is the primary frequency in US and Canada, 900 and 1800mhz are most popular in the rest of the world.
Good luck.
Spotty but improving. The infrastructure is shaky. If you absolutely positively must have comms then call these guys:
Outfitter Satellite at (615) 889 8833.
They rent satellite commo gear like compact satellite phones at reasonable rates for use on the Iridium constellation estbablished by Motorola and now owned by the DoD. They are used by a number of government contractors and the gear works anyhere you can get a satellite. I’ve used this equipment all over the world with perfect results, especially for data transmission.
Cheap and good. 99.5% reliability.
Here’s me using the gear in the middle of exactly no where:
http://www.bikesportmichigan.com/editorials/images/tom-ac.jpg
Interesting that you should point out that the rest of the world is filling in.
The US is the last country that I know of to incorporate GSM networks. This is not a critisicm - moreso - it recognizes the massive change that neds to be undertaken in terms of transmitter towers and then handsets with end users.
GSM is hugely popular in Eruope, Australia and most of Asia. Has been a very well accepted and relaible network.
Be SURE though - to get a quad band phone if you plan to use it overseas!!
AJ
Thanks guys - checking into GSM and Outfitter.
Another quick one - what do you guys use for a power adapter for your notebook? A guy I worked with there last time had an adapter that worked in multiple countries. I’m doing some online searches, but not finding the same kind of thing…can anybody point me in the right direction?
thanks for all the help!
I had to make one that works everywhere. It is a trifle sketchy but I’ve used it everywhere. I made it from an existing voltage converter that I modified.
Satellite phone?! Good Lord man, he’s going to South Africa… not the middle of the Sahara! A GSM cellular phone and SIM card for the South Africa will give you the same exact service and rates that locals get. Their cell service is dominated by Vodacom and MTN who operate at GSM 900 Mhz and GSM 1800 Mhz, so I would recomend getting a tri-mode phone.
