OT Espresso Machine
I am looking at buying an espresso maker and recently ran into a demonstration of the Nespresso D290. I thought this looked like an easy to use machine that was seamless with the easy to use capsules you buy. Has anyone used this model and would you recommend it. I know this is not on topic with tri, although I seem to get good opinions here. Here is a review I found online.
Nespresso D290, $499
Espresso machines are the home-appliance equivalent of six-speed sports cars—they take countless hours to get used to and even then continue to act up. Not so in the case of Nespresso’s handsome D290 model, which is so simple that a 5-year-old could master it and so consistent that I managed to get a near-perfect espresso shot out of it every time. The machine uses small, proprietary capsules—slip one into place, close the cover, press a button, and you’re off to the races (more or less literally, if you’re drinking double shots). On the one hand, this is a significant drawback: The capsules are available only through Nespresso’s Web site, and at 50 cents a pop, they cost slightly more than store-bought beans. On the other hand, the machine is so reliable and easy to use that I found myself overlooking the inconvenience of Nespresso’s online ordering system. The capsules come in nine caffeinated and three decaffeinated varieties, with Italianate names like “Roma,” “Cosi,” and “Decaffeinato Intenso.” All were tasty, and each sported a thicker crema than anything I’d managed to produce with beans I’d ground on my own. The downside here is that if you’re not grinding your own beans, the only way to exert control over the strength and flavor of the espresso is to choose among the available capsules. (I suspect a practiced barista could make a better espresso with most of the semiautomatics reviewed above.) The upside is that neophytes could spend all day trying to make a better cup of espresso—or cappuccino—than the one this machine will produce at the touch of a button.
Grades:
Looks: 9 points
Quality: 8 points
Convenience/Usability: 10 points
Value: 5 points
Total: 32 points
I have one and think it is very, very good. I did have to end up quiting as I was drinking WAY too much. But, the flavor was excellent, and I found it very convienent.
look at the saeco vienna just push the button and its done, awsome coffee.
I have two of the Nespresso machines and they are great. Very simple and easy to use and they make great frothed milk. I heartily recommend them.
I have the Alessi nespresso machine and love it (it’s been 6 years!) http://www.nespresso.com/precom/sima/fiche__NESPRESSO_%26_COBÁN_ALESSI__A_Alessi_3_us_en.html! My parents have the model you mentioned and really like it.
This is old school and AWESOME! $35, put in water and some Illy fine grind, a few minutes on the stove top and VOILA! I heat my milk in the micro, I even have a $12 milk frother. Clean up is a snap. I can’t justify spending hundreds of dollars on an espresso machine. Especially since my reason for buying this is to save money (no more starbuck’s). Not to mention the convenience.
http://www.alohacoffee.info/italian_moka_pot.jpg
This one is hard to beat. We’ve had this almost three years now and had not problems with it. Makes good espresso & coffe. Whole Latte Love is also a good company and provides great service.
http://www.wholelattelove.com/Gaggia/Compact.cfm
Victor
I have a nespresso and like it but also drink way to much now. :slight_smile:
I bought a $199 model. Try one of those and use the $300 you saved to buy something else
What does the more expensive model do that the $199 version does not?
Pre-ground coffee is so wrong on so many levels :slight_smile:
You will never come close to my god shot with that contraption!
http://aycu33.webshots.com/image/5952/2003672311754007654_rs.jpg
I like the Rocky. However I do love my Pavoni Professional. Lever machines - good times!
Maybe someone already mentioned it, but if you’re looking for reviews check out: www.coffeegeek.com. Take a look at the consumer reviews…there is a lot of great information.
I have used the Briel Multi-Pro ES200 for the past 3 years and love it.
I had an Olympia, but when it broke down, replacing it costs four time the original price. Rather than spend $2000 for the best, I got an Anita for $1000 that I like even better than the Olympia. I have a Saeca grinder, $200. None of this is cheap, obviously, but these make actual espresso and not an approximate. I got the Anita at ChrisCoffee.com. Good follow-up. Also, I use reverse osmosis water, as recommended. That’s no big deal for me because I have to make RO/DI water anyhow, for my saltwater fish tank.
No, I’m not filthy rich, but I like nice toys: Calfee bike, iMac, Simac ice cream maker, that sort of stuff. But I drive a cheapy Honda and wear old stuff.
rtk
You gotta go old school here before you drop that kind of money for cafe’!
KEJ ( 8 posts above) hits it on the head!!!
When Italiani go for cafe’, they have it brewed at the bar. The mechanismo per cafe preferita at home… is Alessi pictured above. Every home, apartment, villa, office with a stove, has an Alessi. The fastest, easiest, least expensive best espresso.
I have friends in Italia that will scoff at the idea of needing anything else.
Grind as fine as possible (Turkish). Pack it tightly in the pot.
http://www.bicitreregioni.com
I’m astonished that people spend hundreds or even thousands of dollars on a fancy schmancy machine that doesn’t make espresso any better than what I get from my $35 moka. OK, I do have to steam my own milk, but really that is not worth $2k to me. If you put in quality grinds, you get a great pot of espresso (about 6 shots). Plus it doesn’t take up 1/2 of my kitchen.
I went to Sur La Table to buy an espresso machine, the guy asked if I wanted electric or stove top. I didn’t know anything about the stove top moka. He sold me on how great it is (he must not work on commission).
It really depends on how much you want to spend…like anything. Some would argue their is a difference between the quality and taste of your spro when using espresso pods vs. freshly ground beans. There are also lots of other variables, steam pressure, etc etc. Andrew J can certainly chime in on all teh details. I have a Saeco Incanto and love it. Its been great going on two years now, the only problem is its way too easy and its easy to overdose!! I love mine . I would highly recommend an in home espresso machine!
The biggest problem with super-autos is temperature and grind control. Even expensive super-autos have only a couple grind settings. To make top notch espresso, getting the grind correct is half the battle and most high end grinders have 20 to infinite settings whereas the super-auto might have 3-5. Super-autos usually have a very cheap thermostat, so your water temperature can vary immensely up to 20F. Without control of these two elements, the chances of consistently making great espresso is almost nil.
WOlfwood, All you say maybe true, but all I can say is mine has been making the same great cup for over two years now, the only variation is the taste depending on which beans I use.
If it works for you thats great. Im just going off my own experience. Even the tiniest changes in grind setting have a huge impact on crema. Of course my expectations are very high. If I dont get the proper crema, Ill dump and start over. I have even installed a PID on my machine which gives a digital reading of boiler temperature and allows me to set it within 1F. Its amazing how much more consistent I got with my shots once I was able to maintain proper temperature control, like night and day.
Even with my equipment, Im still lucky to get more than a handful of truly magic shots a week. It takes a lot of skill and experience to get everything just right.
If you wish to enjoy “cafe” l’moda d’Italiani intended, drop the equivalent of 20euros, on this one. You’re going to love the Italian simplicity, process, and coffee. Bring the other $465 to Italia, and we can discuss cafe with a barista.
credit photo - KEJ
