OT: Best ipod portable speakers?
For Christmas my wife would like portable speakers for our ipod. She will mostly use it in our kitchen / family room and down in our basement play area with our children. I checked out ipodlounge.com and I am leaning towards the Logic3 iStation7. It looks like a good balance of price, portability, and quality. Any suggestions or recommendations? Thanks.
I have the Altec Lansing iM7 and have been very pleased with it. iLounge.com has an extensive review of it and I believe rated it at A-. I use mine in different rooms of the house and can vouch that it does great for filling big rooms with sound.
Yes, I was considering that one as well. Thanks.
so, um, there’s this other forum here…
If you don’t need a boom-box type system, I would strongly recommend that you try a pair of self-powered/internally amplified studio monitors. You can buy a set of these for anywhere from a couple of hundred dollars to, well… several thousand dollars, and even the least expensive will absolutely destroy any Ipod-specific system on the market.
Depending on your level of audio-snobbishness (which probably isn’t that high if you are looking for this type of a system,) this can be a very plug and play setup, as most of these type of devices can be run directly off of a feed from the headphone-out jack on the Ipod, with the Ipods volume control used as an overall system gain control.
I use a Bosch radio at work(construction wood butcher)
It is large , rugged and loud Charges tool batteries.
might be to much for the kitchen :slight_smile:
http://bosch.cpotools.com/other_tools_and_equipment/power_box_radio/pb10-cd.html
Dirt
If someone was going to do that, they’d probably want to use the Universal dock to connect the monitors. That way the iPod would stay charged and they could use an audio line-out connection through the dock…
"If someone was going to do that, they’d probably want to use the Universal dock to connect the monitors. That way the iPod would stay charged and they could use an audio line-out connection through the dock… "
Depends. That would be the “best” way to do it (and is how I do it,) but not necessarily the easiest. If you aren’t concerned about keeping the Ipod on charge when you listen to it, aren’t audiophile wonky, or if your speakers don’t have adjustable gain, using the HP out would be fine/more appropriate - and easier!
Either way, you will get more bang for your buck -and better sound quality - going this route than resorting to some atrocious Bose monstrosity or other of the same ilk.
I have to admit, though, that I really like a couple of the Tivoli Audio products - http://www.tivoliaudio.com/
If you absolutely have to get an all-in one mini system, they make some nice stuff - and I know several super tweaky audio guys who patch the Model 1 or Satellite into their high end component rigs as a radio source…
I was checking some of the Tivoli’s out the other day…they have them at Target now!
Great stuff!
Funny thing… I lived in Tivoli for a while when I was in college. It’s a tiny little town in New York… small world.
RE: Target - good for them! It’s great to see a little company have success with a niche product done exceptionally well.
Do you mean I should have posted over in Tibb’s? I can move it - sorry.
Logitech mm50…very portable, decent sound, has a remote, comes in a travel case, easily packed…
Yes, just checked it out and great suggestion. Good price point. Thanks!
Costco has them for $99.00!..I paid $150.00…and now they come in black!..sweet
I like the fact that they recharge the batteries…they are the best sounding most portable compromise…IMHO
here’s what i have…
http://www.onqlegrand.com/images/solutions/diagrams/diagram_Extreme_Music_large.gif
EDIT: You have to be able to pull wires through your walls, plus the cost is like $5k ish.
I carried my 17lb Apple HiFi speaker (!!) with me to and from Germany without any problem.
And BTW, I found mine on eBay for 202.00 (reg $349).
Price? YMMW
Portability? Two handles allow for carry around, place wherever for ambience
Quality? Can’t beat it unless you’re willing to go with a monitor-like system say from “Listen Up” in Colorado (shameless plug; sorry).
Don’t go cheap.
Just do it.
Merry Holidays,
If took this suggestion could I use them with my laptop too then? I would like to be able to use the same set with my laptop? Mind pointing me to a link or brand I can check out?
I don’t care about the charging of my Ipod so this is a good dual solution.
"If took this suggestion could I use them with my laptop too then? I would like to be able to use the same set with my laptop? Mind pointing me to a link or brand I can check out? "
Yes, you could.
Google *powered studio monitors *and you will find about 1000 links, or maybe check out these:
http://mixonline.com/mag/audio_krk_rokit_rp/
A friend has a pair and likes them…
