How do you know if you need orthotics for your running shoes? I ran for years through Highschool and into college and never worried about such things. Then my senior year I developed ITB while training for a Tri. I went to a very good Otho Guy and they did therapy and fitted me for Orthotics. They were very clumbsy fdeeling and I hated the feel on my foot. I stoped wearing them when I took up cycling and quit running. Fast foward 12 years. I am now running and doing Tris again. Two years ago I went to a Pediatrist? and he fitted me for Orthodics. My insurance paid for it all, cool. Now I need new othodics, but my insurance will not cover them. I am thinking of using (superfeet) or are todays stability shoes good enough?
I had ITB 3 years ago, and fixed it w/o orthotics (against the recommendation of the chiro I saw one time only). I think they are over “prescribed”, seen as a nice money maker for some chiros, etc. Many people have other root causes that show up as symptoms (ITB, piriformis, etc.) that chiros/podiatrists/et al try to treat with orthotics. I say make sure there isn’t something else going on first. Get with a good sport physiotherapist, get your gait analyzed, all that stuff. My philosophy is to try and fix the root cause than to modify the environmental factors FIRST. Humans have been running for how long now? We’re designed for long distance running (ref: Science journal Jan 2005), so you should be able to run pain free if your body mechanics are sound (granted 10000 yrs ago everything wasn’t paved over either, but you get my point I hope)
This guy did my bike positioning, cycling orthotics and also makes the Superfeet product. He does gait analysis and all the high tech stuff used to evaluate you. I had ITB a few years back and his combo of cycling orthotics, changing my cleat alignment, Superfeet in my running shoes and a slight correction of my saddle position took care of the issue, improved my power on the bike and my comfort on the run. I can’t recommend him enough if you are close enough to one of his locations. Jim(?) Pederson of Foot Fitness. www.wedofeet.com
Motion control and stability shoes prevent the feet from pronating and supinating, giving a straight heel alignment. Orthotics or other inserts, including the ones that come with the shoes are meant to support the arch and prevent it’s collapse.
Ideally you would run barefoot regularly and be the perfet POSE student, and your supportive musculature in your foot would require these man-made oddities. But you don’t. So, put something in your shoe to support your arch. The factory insert is OK, but may not be high enough for your arch, and may wear out quickly. Superfeet should last through two pairs of shoes, or so. Custom orthotics should last thorugh many pairs of shoes depending on what they are made out of.
I got plantar faciitis, because my arch kept collapsing. Add orthotics and no more problems.
