Orbea Ora Size
I’m planning on buying an Orbe Ora (same geometry as the Ordu) but I don’t have the chance to try one before, so I need all the help I can get regarding sizes.
I’m a bit confused about size.
Today I’ve a Cannondale R1000 (CAD8) as a road bike on a 58 size, that I believe is a little bit on the bigger side.
Has an extra information I’ve 6’1’’ (186cm) Height, 2’3’’(69cm) Torso and 2’10’’ (87cm) Inseam.
Can someone help me?
I am 1m92 cm and have an inseam of 91 cm. I sit perfectly on a 57 frame. With your height I would consider a 54 frame. The only thing you should know is that the head tube is very short (10 cm) so if you have a good back I would choose the 54 frame.
I ride in 76 angle and the top tube is ok.
I have the Orbea Orca 60, so the sizer of the Ora are quit big.
You should be fine on a 54 Ordu
Thanks a lot!
Your height and inseam, please.
I think to buy a new ORA 2008 and I have a size doubt.
I am 6’ and 33.5" inseam
I am 5’ and 9.5" tall (178cm) and inseam 32,8" (83.5 cm).
for me, the problem is the head tube in 51 size, my back cant will endure.
I think that I look for other brand.
