Opinions wanted on bike upgrade from Kilo to KM40?
Hey guys, I currently ride an older QR Kilo with 650c wheels. I have been pretty happy with this bike overall, but realize that it’s not the best bike out there. I have an opportunity to buy a Kestrel KM40 pretty cheap, which also has 650c wheels (so I can use my Zipp wheels), and is full DuraAce.
Questions are: Would I really notice much difference by switching to the Kestrel? Advantages as I see them are: carbon frame (comfort), better components, and aero frame.
Should I bother with trying to buy this bike?
Thanks for your advice.
Jason
Does anyone have opinions of these 2 bikes?
The main thing to consider with these two bikes is the difference in fit. Is is an old KM40 with the seat tube? If it’s that old, that frame fits really big. If is it he newer one without the seat tube, is it a 56 or a 52?
The components may be better, but you can easily upgrade for your Kilo. The frame may or may not be more comfortable. I have found that comfort for me is more a function of how a bike fits and what seat, bars, and wheels I use rather than the frame material…I’ve also ridden a seat-tube less kestrel and it was very comfortable. And, yes the kestrel will be a bit more aero.
So, to sounds cliche, it will come down to how the fit compares on the two bikes. The kestrel KM40 has a long top tube if my memory is correct. The QR is steeper. The KM40 has not been made in quite a few years either.
Sounds like you’re not sure what you want out of a new bike - is it to be faster? Probably won’t notice a difference.
I went from a Nishiki Altron (mainly steel 650c frame) to a KM40. There was a difference in the dampening of bumps, in fact I test rode many bikes at Nitro and preferred the Kestrel to a Cervelo P3, Litespeed Blade, and even felt it was more comfortable than a Softride. I’m pretty sure you will notice a difference in how bumps feel. It may not make you any faster (and I think frame aerodynamics are very over blown), but if you enjoy riding more you will eventually get faster by being out there more.
As others have mentioned, the main thing with the KM40 is making sure it fits. They tend have rather tall head tubes and fairly long top tubes also. Mine was a good fit when I was satisfied with little to no seat to aerobar drop, but to get a lower position I found I needed to go to a Look stem (which is fine).
You don’t mention what components the Kilo has. I’ve run Dura-Ace, Ultegra, Record, and Chorus in various combinations on various bikes. Other than my preference for the Campy hubs, I can’t honestly say I can tell much difference in the rest…it’s more about looks and snob appeal.
If you are pretty sure the KM40 will satisfy your bike lust for several years, go for it. Remember that the KM40 is fairly old as well, so if your looking to have the latest/greatest I’d say save your money for awhile.
Compare your top tube lengths carefully on these. Be sure you know what you want. The reason I mention this firstly is that I think you are going to see a trend toward a slightly short-ish top tube on your Kilo and perhaps a trend toward a good bit longer top tube onthe KM40. That is going to affect how the bikes feel.
You will absolutely notice a difference in comfort immediately. The KM40 is even more comfortable than other carbon frames that are build SPECIFICALLY with comfort as the primary ride characteristic (Aegis Trident in my case). Additionally, those babies are wicked fast. I am averaging approximately .6 mph faster over my various training rides vs. the fastest I ever rode last year on my Aegis. N=1 of course, but I have seen major improvement in my ability to stay aero and put down the watts.
Like others have said, there is definitely the caveat that the bike needs to fit. It should not be difficult to get the top tube measurement and make sure that you can achieve a good position ont his frame.
If it’s the KM40 in the classifieds right now, I would not hesitate for a moment. That thing is beautiful and looks to have been taken care of by a very anal retentive owner (always good in the case of bikes and expensive aero wheels).
Chris
The Kilo I have now is a 57cm, and the Kestrel I’m considering is the 56cm size. I know that Kestrel’s run a little large (and QR a little small in top tube length), so I’m thinking this would work for me.
I was going to check the specific dimensions before making the commitment to buy.
I mainly want to upgrade for speed (of course) and comfort, but the added “Cool” look of the KM40 is a bonus also.
Thanks again
Going from the Kilo to the Kestrel, you will want a forward seatpost.
If your legs are pretty short compared to torso, you could try the Corima…that thing is crazy aero. IronDad runs one of those IIRC.
Other options are:
Bontrager Race X Lite or Race XXX Lite with the 20mm offset flipped forward.
Profile Design Fast Forward (original which is ugly, or the newer carbon model).
Eason CT2 20mm offset flipped forward
This will put you into the 79-80 degree range and scale the top tube down to where you need it (probably 55cm if your Kilo is a 57).
Chris
I don’t have an opinion on the QR–other than suspecting that its Slowman heritage means it’s likely to be very good–but I am quite fond of my KM40. I think you’re on the right track on sizing. I ride a 58 road bike and a 56 KM40. Don’t rule out the possibility of needing to change saddle position and maybe even stem, however.
The KM40 was my first real tri bike when I bought it 12 years ago. It did make me faster, but that’s probably largely because I just like riding it so much. I bought it because I wanted it, not for any rational reason, and no rational or emotional reason has tempted me to replace it since then.
The only downside to the KM40 is common to all carbon bikes, as far as I know. The paint tends to be more tender than that of metal bikes because it can’t be baked.
David
If you got yours in 95, doesn’t that make it a totally different bike? There was a KM40 in the early 90’s with a seat tube (my dad has one in his collection), but I think we’re talking about the seat-tubeless model that came out a bit later.
I could be wrong as I don’t know exact production dates, but I haven’t seen a KM40 Airfoil previous to ~1999 or so.
Chris
It’s a non-seat-tube frame (the first year I think) badged as an Airfoil. I could be wrong about the year–I didn’t fish out the invoice, and the 55-59 age group has proved hard on my memory–but it’s not much newer than that.
Good to know, thanks for the info. I’ll just have to call my dude at Kestrel and ask.
Thanks,
Chris
Thanks for all of the input. I’m still undecided, so I may hold off for a while.
My Kilo is a '98 model, back in the day of the 78 degree seatangle, and it’s a solid, dependable bike. I feel very comfortable on it, and am only looking at the KM40 as a possibility of being a little faster and smoother.
But in reality, I honestly think I’m in between the 2 sizes of the KM40, because I tend to like a slightly shorter top tube. Being 6’ tall with a 34.5" inseam and fairly short torso, I’m not sure either of the Kestrel sizes (52 or 56) would fit me as close as the Kilo. Any of you about my same size ride a KM40?
Your built opposite of me. I’m 6’ tall with about 33 for an inseam. You’d probably wind up pretty short on the stem and long in the seat post.
You’re pretty close to me, but actually more proportional in the right direction (longer torso).
I am 5’11" with a 36" inseam. Currently riding the 56cm with a 20mm offset Bontrager Race X Lite pointed forward (so the top tube is more like 55.5), and I am currently running a -17 degree 100mm Ritchey 4-axis stem. I have a 90mm on the way to try as well, but I don’t know if I will have to go with that. I would guess that you are long enough in the top to run a 100mm as long as you use the same or similar forward seatpost solution.
This is a perfect setup for long course tri. I couldn’t be happier.
Chris
