Opinions needed: The Correct Temperature for Planet Earth
According to eco-terrorist freaks, we are feeling the effects of ‘Global Warming.” And it’s a serious fucking emergency to fix it. Global Warming is our fault. Somehow over the last 30 years, man-kind has managed to fuck up the climate in a way not seen over the previous 4.5 billion years. Nothing like this has ever happened before according to people who were not around 4.5 billion years ago, but I digress….
How can we agree on the correct temperature for the planet? Since Al Gore and his followers are trying to convince us that we are causing global warming…….with no consideration for natural phenomenon……if we are the cause, we are also the cure. If Al and his followers can so precisely identify the causes of global warming, I don’t think it is unreasonable for Al Gore to set the thermostat for us. After all, if we caused it, we can fix it.
Therefore, with respect for the “science” and “knowledge” that represents the leading edge of global warming gayness, what is the correct temperature for planet earth? If we don’t defer authority to Al Gore to set the thermostat, could we vote on it ourselves? Or, would we accept what Al tells us and behave accordingly?
I, The Great Mojozenmaster, never desiring to complain about a problem without offering a solution, have determined that the correct temperature for all Human Beings to exist happily on Gods great green Earth is 73.7 degrees.
What do you think?
4 K, think how much faster computers would run!
Checking my calendar,…yep, it’s about that time of month again. Time for the random Mojo GW rant.
If all you can do is question/critique the ‘timing’ of my post, I have determined, that you have determined, my post represents the highest form of wisdom and knowledge, in any form, for my quest to confront and conquer the hypocrisy of global warming gayness.
I am pretty sure we need to get the temperature back to where it was at the earliest known time we have been able to reliably sample.
The recent DNA finds from Greenland show that the area was obviously much warmer than thought, maybe about 10 degrees warmer than now, since Greenland was actually green at the sample site about 500,000 years ago and now it is covered in 1.2 miles of ice.
We probably need to fire up Hummer production to get things back to the way they were.
Can’t help to be a little disappointed in you Mojo for not noticing this pin in the Global Warming balloon:
http://global-warming.accuweather.com/...ffers_clue_to_g.html
68 degrees fahrenheit would suit me just fine. Low 50’s at night, even better.
I like the warmer weather personally. I also could do with a fairly short winter. I’m still trying to figure out why I continue to live in Michigan. Work and family I suppose.
Bernie
That is really only a small part of the problem, Ken. We are not talking about long periods of time here in geologic terms. We are talking about a huge temperature change over a geologically short period of time. It is not like Greenland was closer to the equator during the relevant times.
More importantly it shows that the temperature chart you posted in the other thread I resurrected showing the temperature of the Earth over time is likely completely and totally wrong. Whatever data was used to generate it can’t explain these findings. If your fundamental data is now in question, don’t your conclusions based on that date need to be questioned as well?
If you can’t get close on the value of the variable, in this case temperature, it is a good bet you are completely clueless on the first derivative as well.
If there is one thing I am more certain of than statements of certainty about the distant past likely being proven wrong, it is that predictions of the future will almost certainly be wrong.
Ken–The meat industry is responsible for about 20% of the worlds greenhouse gases. This study is an international study which was published in the journal “Science” was co-written by University of Alberta Glaciologist Dr. Martin Sharp.
Maybe you can find out if that was funded by Big Meat?
Art–when evaluating GW, only the last thirty years count.
**Art–when evaluating GW, only the last thirty years count. **
Shit, that always trips me up.
:wink:
First off, I have expectations that the great mojozenmaster would TELL me what my opinions are or should be. What is this crap about asking for my opinion?
“we are causing global warming…….with no consideration for natural phenomenon……”
Second, who says that there is no consideration for natural phenomenon? Everything I’ve ever read about global warming…save from the right wing freak shows…address natural cycles of warming and cooling. I just want to know where you’re coming from so I can alter my thoughts and memories. I’m trying to build up that skill as we move closer and closer to Orwellian society.
“We probably need to fire up Hummer production to get things back to the way they were.”
I don’t know. Hummer top speed is 88 mph. Prius top speed is 100 + mph. Only a slow pussy would drive a Hummer.
OK, Fatmouse. That was good.
Keep in mind … it’s not the heat, it’s the humidity
“my post represents the highest form of wisdom and knowledge”
They always do my friend. They always do.
