I’m fairly new to triathlons and already own a Specialized Allez road bike.
A co-worker loaned me his Elite Racing tri bike circa 2000 – 54cm, dura ace components, carbon 650 wheelset. He raced it in Kona.
It seems to fit me ok.
I’ve offered to purchase for a reasonable amount, but am having second thoughts. Should I buy a new entry level tri bike instead, (Cervelo, QR) ? I’m on a budget.
Not familiar with that bike, but regardless, some things to think about (in no particular order):
8 Speed? 9 speed? How much will it cost you to upgrade to 10 speed if/when you get the itch?
“Seems to fit me OK”… don’t sell yourself on a bike that almost fits because it’s good deal. Your buddy knocking off an extra $300 isn’t going to make it fit any better.
Do you really need a tri bike or are you thinking about this because the opportunity has presented itself?
Are 650 wheels right for you? They might be, but a question you should probably answer before you plonk down the cash.
“He raced it in Kona”… So?
How’s the price compared to a new entry level tri bike?
Will it make you faster? Are you in the M30-34 age group? If so, skip it.
Food for thought… just don’t fall into the mindset of “I kissed the girl, so now I have to marry her”.
Elite is a great bike. There is nothing wrong with 650c. For a 2000 bike, it is probably 9 speed but look into that - 8 speed can be tough to find now, so you would have to probably upgrade before too long.
I have short legs and arms and a long torso. I think that 650 tends to hit me better for the lower possible stacks (less prevalent now due to super low stack 700c bikes). - so it depends on fit. I sold my older QR Aerial this winter, which is a great 650c bike. I am probably going to get an older P3 54cm 650c bike as a replacement in the fall. There is plenty of 650c stuff around, just not at the local LBS.
As stated above, the key is fit. Invest in a good fit. See if the guy will let you take the bike to a fitter (independent preferably) and see what the fitter says. Go from there in your evaluation.
What are your short term goals? That may help the decision process as you may not even need a new/different bike. Then, as you lay out your long term goals you can decide if a new bike will be worthwhile.
FWIW, I raced an Allez for a couple of seasons before buying a tri bike. I flipped/dropped the stem, added clip-ons, jammed the seat forward and was able to get a reasonable aero position. I’ve since converted it back to road use for group rides.
