Old km40 vs. new Cervelo P2
I’m debating about whether or not to take the plunge and buy a new P2 carbon. I’m currently riding a 1997 or 1998 Kestrel KM40. The advantages are that I already have a disc and H3 wheelset for it, and used 650 wheels are cheap to replace if I need to. It’s got a great feel, but I’m running into some problems. The paint has chipped so much that it is starting to look like a beat-up bike. It also has the older bottom bracket(dura ace 9 components), and a quill stem for the headset. I want more drop, but the quill stem is already the lowest it can get, so I’ll need to replace it with a stem adapter, and buy a new stem. I also need to replace the crankset.
I’m debating about whether or not to start over with equipment purchases. Since it has 9 speed components and 650 wheels, everything I’ve got besides my seat and my helmet will have to go with the bike.
If I were to go to a cervelo or a new kestrel, where is the most inexpensive place to purchase one? The local bike shop only sells trek and lemond.
I’ll take any advice or suggestions people have.
If your H3 is a clincher and is in good shape I will buy it from you.
As for the P2C, a great bike, my next bike…someday. I really think it is the perfect balance of price and performance. No matter where you look it’s going to be $2,000 for the frameset or $3,000 for the complete bike (unless you have some sort of connections).
It’s a lot cheaper to buy a new stem (even an ergostem) and crank than a new bike and race wheels. I’m also not sure why any triathlete would spend the money on one of the new style cranks if they already own a crank that isn’t broken since they only make a difference under power and triathlon is an endurance, not power, event. If your Kestrel is one of the ones with no seat tube, an external bearing crank is likely to have even less than normal impact. If it’s a race bike, do the chips really matter?
This is a case of the pot calling the kettle black since I’m always looking for an excuse for a new bike. However, if your Kestrel is one of the ones with no seat tube, you probably would notice a performance improvement with a Cervelo.
Moth ball the old KM0…I owned 2 of them…great bikes …but way outdated…The Cervelo will serve you well…do it.
I’ve responded to your PM about the wheels, not sure if you got it or not or if you’ll see this. But I am definately interested.
Don’t do it, captain!
The feel of a KM40 is hard to beat for long distance tri, and it’s a fast bike from an aero standpoint.
If you are looking to update things a bit, I would do the following:
  1. Forward seatpost that will get you a few degrees steeper. ~$60
  2. QR Carbon Aero fork w/ cane creek s2 headset and adjustable stem. ~$120
  3. Dura ace 10spd Hollowtech II crankset $160 (be patient and you can find them)
The most important of those is the QR fork. You absolutely NEED that fork if you are running a front H3. It has the best drag numbers of any fork ever tested with the H3, and will be considerably faster than the stock kestrel.
Chris
