Ok, so what happened to square planets?
I’m wasting too much time today googling oddball shit. This one has been bugging me for a while: Why are stars and planets round?
Why are stars and planets spherical? Why aren’t they cubes or ovals?
The shape of small objects (like people and houses and mountains and small asteroids) are determined by their mechanical properties. You can take a rock and cut it into a particular shape and it will pretty much stay that way.
The larger the object, though, the stronger its gravitational field. Imagine that you want to build a really tall building. You have to make sure it has a really strong foundation, or the foundation will be crushed by the weight of the building and the building will fall. If you there was anything really big sticking up on a planet or a star, gravity would pull it down.
If a planet was like a cube, the corners of the cube would be higher than the rest of the planet. Since planets and stars are so big, you cannot build a “foundation” strong enough to hold up those corners! Anything you built it out of would be too weak to hold them up. Gravity would eventually pull them down.
Stars are made of gas. Even solid rock will flow like a liquid, although very slowly, if it is pulled by a very strong gravitational force for a very long time. Corners on a cubical planet or star would eventually just squish down.
Since gravity pulls toward the center of the planet, everything gets pulled down into a ball. However, planets and stars are not really perfect spheres. They spin, so they bulge out a little around the equator.
Is that a hypothesis, a theory, or fact?
Have you read nothing on this forum?
Planets are round because God made them that way. End of story.
He probably moulded them that way in the image of his own… round bits.
I thought all this was common knowledge. What’s interesting is that asteroids, which have much smaller gravitational fields, are more likely to deviate significantly from a spherical shape.
