Official Fit Assistance for Profile Design Bars
No accident, rear of pad.
Thank you!
Thanks for that info… so are you suggesting the A3 bracket would give me extra tilt AND extra reach? I don’t need to use the reach extender I already have if that is the case, the setup you suggest seems like it would be much cleaner.
Here is the slide from when I first explained to the sales team the improvements in the A3 bracket:
The reach extender gives the A2 bracket the same range as the A3 has built in. The A3 can use the reach extender too.
You can also see that when tilted, the A2 shifts back a long way, where the A3 has been engineered to keep the x differential to a minimum.
The only reason to source an A2 bracket would be for the lowest possible stack (and your bar angle is 15 or less). Otherwise the A3 is definitely the cleanest way to have all the adjustment available.
Awesome, thanks so much! I’m sold, ordering one now :slight_smile:
@cyclenutnz Really appreciate any help you can give. I am trying get a cockpit that isn’t a bunch of thrown together parts to get the reach, stack, and angle I want, if possible, without buying a whole new frame as this one has worked well for over two years.
I think the Wing 20c+ II and A3 brackets could work. I am running a 105mm PD Tri-stem currently with Ergo+ armrests. I plan to keep using those. Back of pads are currently 32mm in front of and 160mm above the center of the base bar clamping area with a 25 degree tilt.
I would love to have the ability to add a bit more reach. I currently don’t for safety reasons. It’s my understanding that forward facing A3 bracket with an extender and the high rise bridge kit should work. Will I also be able to get enough height?
Thank you!
Pad X 527
Pad Y 725
Tilt: 25 degrees
Frame: Winowsport TT-119 56cm
I’ve used the P3 for the calc as I don’t have the Winow in there and the dimensions are only different by 1mm of stack. Should be close enough
Yes you can just get to the 527 Pad X with the A3 Bracket. Stretching out will require the reach extender. And yes, the A3 High Riser Kit.
