Sorry for slow reply, it’s a bit more involved than the normal calc.
I do need to clarify where you’ve measured the Pad X to?
If it’s rear, the closest I can get is 498 with a stem to fit the HSF Aeria
If it’s centre then it’s less of a drama.
Sorry that’s an important piece of info I should have specified. 510 is to pad center.
Thanks.
Can you give me 660mm pad stack and 515mm pad reach to back of pad w/ 15* of tilt for Aeria Ultimate bar and stem? What would that backwards calculate to frame stack and reach? I’m in between two frame sizes… QR PR5.
As far as I can tell it takes ~20mm of spacers (incl hset cover) to match the height of the QR bento
But the 56 is nearly at max pad reach (11 out of 12 row options where 1 is most set back)
58.5 is a less extreme pad position (but gives the room to lengthen out)
The difference between pad row column and description is that description splits the high level view down to exact placement on the bracket
Thanks, I suspected as much. The client is in between sizes from both a fit and a bar choice perspective.
I’m trying to find the vertical height gain measurement of the 50 degree extensions, but at a loss. Do you know the measurement from centre to top? Thanks.
I was under the impression that Aeria Ultimate had pad and aero extension tilt capability, but I’m on the Profile Design site and that does not appear to be the case unless I’m missing it. There is plenty of lateral (left and right, fore and aft, and some toe-in), and a ton of vertical adjustment with many riser options, but I don’t see angled shims to tilt. Is there a way to add any pad and extension tilt? -c
You have an Aeria 1, not an Aeria 2 (which the UItimate is).
If you have an Aeria 1 you can’t use the Aeria 2 brackets, you would need to order an Evo bracket https://profile-design.com/...ucts/evo-bracket-kit
The Evo was designed specifically to add tilt to the older model bar - PD had sold many thousands of those so didn’t want to leave users without a solution to add tilt and better adjustment range
New products shown at Eurobike (continuing from the thread about WS)
Everything aside from the brackets is new in this image
43ASC (aero shaped carbon) extensions with Race+ armrests on a Wing Ultimate basebar
The principle behind the extension was to sweep the extension body across and up to where the riders arm is. The idea being to make one body from the perspective of the wind. CFD analysis was promising and led to the fin that tucks into the inside of the wrist.
Obviously there are length constraints, so a shorter option will follow a few months after this one.
Race+ armrest is a 40mm longer version of the Race, with a new 5-10-5mm tapered pad and grooved surface (same as Ergo+) for traction and moisture wicking
Wing Ultimate addresses the weight penalty of the Aeria Ultimate stem by integrating the stem.
Do you have any idea how to get angle adjustment on a J5/Supersonic bracket with risers (I think 50mm). Rotating around basebar leads to other fit problems…
Also, how long will the ASC extensions be in the large version uncut?
