Here are some 2014 color…
Are they speccing a 3T Brezza on the di2 version this year?
Track Machine TR01 and TR02 in the background as well as TMR02 aero road bike, same as the TMR01 but with a standard front brake.
http://www.ebay.com/…;hash=item2eb0a3b94c
Thanks. I did buy some flexy noodles but had no further success with them.
Just curious for the mounting of the DA / VR bottle - do you use the DA-specific frame mount or the generic, and do you know which of the two fits best for the TM01 seat tube? Planning on doing the same setup. Thanks
Honestly, I dont know which one is which. The one I use has a “U” shape that hugs the tube very nicely (I would guess its the Felt, but Id ask them just to be sure). I have another mount for the VR bottle that is more like a standard bottle mount that curves away from the tube. I use this one one the GF’s size small TM01. The mounting position is a bit more forgiving.
Depending on the bike size you may need to make a new hole. Also depends on how low you want it to fit in there. On mine (size M/L) i made a new hole and only mount it with one screw. Its survived many a bumps without issue. I know on the size small the fit is a bit different in that the VR bottle is a bit too long to slide all the way down by the bottom bracket (it runs in to the down tube) so you are limited on how low it can be mounted.
Hey guys, i need help.
I do not know how it happened, but the frame of my new BMC TM02 cracked.
There is a crack around 1cm on the bottom of the top tube, near the seat tube.Just below the screw which adjust the seat.
I am in doubt what to do. Is it necessary to fix? Is dangerous ride the bike with this?
Thank you.
You over tightened the seat tube clamp. When you do the bolt pushes in to the bottom of the top tube near the joint with the seat tube. Im guessing there is a little bump on that diagonal piece at the joint right? How safe it is depends on how much the bolt caused a protrusion. Ive known another person who did the same thing and had a small pimple like bump, but it didnt break through the carbon. That bike is and continues to be fine. Its a redundant area thats really only there to accommodate the seat post clamp. That being said, it all depends how hard you pushed the bolt through… realistically you are fine though.
Lesson: Go buy a torque wrench. Torque specs are on there for a reason.
Before you go drilling holes in your frame, try the X-Lab Aero Optimizer. It will let you move the cage up or down about 1.75" for a better fit.
You dont drill a hole in the frame. You drill the hole in the bottle cage. Adding that X-Lab thing will make the bottle further from the seat tube and not fit as low because it will run in the the down tube sooner (higher).
Thank you.
After reading time posts, so check out my TM01 and found out what the problem was / is.
The bolt that spans saddle pin solid is 2-3mm too long.
I have taken a picture into the saddle tube and you can see that the bolt just created a brand. And it’s not too tight, I use the torque wrench and it is tight 7.5Nm
So I would suggest everyone who has a TM 01/02 to check it, so do not get ruined your frame.
My frame is fortunately not broken.
The tips on this thread have really helped me setup my bike . For starters I’ve ordered a torque wrench to do the seatpost!
The brakes were a total PITA but after a week of playing around and sandpapering brake pads for my 808 firecrest, they actually feel pretty good (I’m using the new swissstop black prince pads which feel even better than the yellow kings).
I’m running a rotor3d crank set with a power2max power meter (a company in Germany) which has been great and more importantly matches the colour scheme.
I like the stem system, but in my normal position the stem looked like it was a King Cobra about to strike. So i bought some ADR carbon ultra bars (a UK company) which have a but-load of stack and look cool (IMO!).
I have also put some heat lagging instead of bar tape to keep the clean look - its a building supply that contracts when you use a heat gun on it.
Di2 upgrade next season - I can’t take any more bike building this year, I came close to throwing the time machine out of the window once or twice!
my frame is ok as well, always torque properly.
Super nice! I put my computer between my shifters so I don’t have to look back too far. Very pretty bike!
I have stripped the seatpost screw of my TM01. Any suggestions? I am somehow reluctant to use a drill to remove the screws’ head as it is the screw inside the frame. I’m clueless…
Any suggestions veryvery welcome!
Took out the seatpost of the TM01 this past weekend to check the seatclamp bolt and sure enough it hit into the frame but barely tiniest little nick so I’m good to go no cracks. Cut the bolt down then put the seatpost back in and torqued it back to spec. Can’t wait to hop on it for the first race this weekend.
Where did you get that aero bottle mount bracket? I’ve been looking for one
@Jezza or anyone, where is you get that aero water bottle mount? I have been looking for one.
