If you look at Lance vs Jan, you could almost say that yearly, Jan would lost the TdF in December. Why…he’d gain 15 lbs and then have to “burn it off” as he ramped up his spring cycling volume. Lance would gain 1-2 lbs and never have to waste valuable build time working against his own body.
I was having a discussion with a friend of mine and he would like to drop from ~180 to 160 before tri season next year. I encouraged him to lose some weight for optimal performance, but not to lose too much weight. More like a lb for 3 out of 4 weeks a month for 3-4 months (total of 10 lbs or so over 4 months).
The focus of this posting is “when to lose” weight.
If you are already super duper lean, gaining a couple of lbs in the off season is fine…in fact healthy. But pulling a Jan means that you are going to have to lose weight as you do your spring volume build. This is bad.
Why is this bad ?
When you are ramping big volume (say 15-25 hours per week), you want your body to be in a state of equilbrium (as much as humanly possible). You want to recover from one workout to the next. You need to “carb up” to some extent for those 6 hour rides or 3 hour runs. You need to get enough protein post workouts to rebuild. In short, you’re going to be eating a lot a and don’t want to limit calories.
If you really ramp volume and are also limiting caloric intake, then you feel perpetually fried. Your body is fighting to get back to its “entry weight” that it was at before you started doing huge volume. In talking to several atheltes, they feel better in big volume phases when they are not losing too much weight at the same time. A few lbs here or there will drop off, but 10’s of lbs usually means that burnout is not far over the horizon. I’ve seen it happen to too many good athletes.
So where does that leave us?
Realistically, the off season is not the time to pile on lbs. If you are a few tens of lbs over your ideal projected race weight, it would seem to make more sense, to work on getting to somewhere in the range of next year’s goal weight now, while training lower volumes and perhaps limiting caloric intake somewhat. At least this way, you are not fried for all your workout (given that they are a lot shorter and lighter).
Sheila Kealey, one of the top masters XC ski racers in Canada and also a top masters triathlete writes an excellent series on nutrition. The focus of the latest article centres around strategies for limiting unneccessary calories when we don’t need them:
http://www.xcottawa.ca/article246.php
In general, the articles are well written and thought out.
I’m no expert on diet, but what I do know is that huge volume training and dropping large amounts of weight don’t go hand in hand. The school of experience tells me that this is true. So it seems to me that November is when you want to start your “body composition reset plan” for 2006.
Dieticians, coaches, and doctors, please comment on these observations from a layman. Does this make sense?
Dev
