Ok, to all of you with ocean experience. What is the best way to prevent sea sickness in really wavy water? I just did my first ocean swim and it was quite he wakeup. Does graval work? Or does that leave you feeling groggy for the rest of the day? Any recommendations?
Practice, practice, practice. There is no substitute.
Any kind of drugs against sea-sickness will have side-effects (most are not helping your race) and/or you might be cheating, since they are on the list.
All I can suggest is a very light breakfast (or none at all) race morning (for the sake of your fellow competitors).
There are people with more experience on this than me, but I would try a couple of things if I had a swim and felt blaaaagh. I would make sure I get in the water…all the way under and get warmed up before the swim. Get that cold water into and around the ears. Try not to shake your head…roll your body. I know alternate breathing to both sides is ideal, but it may work better just to roll to one side for a while (10-15 strokes) then switch. Be smooth and power through and concentrate on something else…count strokes, see if the person in front of you has a really long second toe, etc. Best of luck and hope some others have some better advice on short notice.
I agree - I get sea sick but didn’t have any problems with the rolling waves last weekend - although I thought I would. Relax and let go with the water and you will be fine.
I have the same problem! In fact, it’s so bad with me that I even feel wheezy when I swim on my back in the pool. the constant rocking back and forth with each arm pull gets me nauseous. I can’t take the back seat of a car, a merry-go-round, a swing, etc. When I went to Hawaii my 1st year, I was really concerned about this. The first day I went for a practice swim and was sick for the rest of the day! The second day, the same thing happened. I talked to some friends about it and they suggested I look at the persons feet in front of me or just relax and look around under water, it’s just beautiful there. Well that got me thru my swim and the next four other years after that. I still get sick in the pool, back seats of cars, etc. but when I’m racing, I just concentrate on the persons feet ahead of me and get down to business. I don’t think you ever get rid of that motion sensitivity, more to do with the inner ear and balance (probably the balance mechanism -tiny hairs in the inner ear- are just to sensitive), but you can overcome it by concentrating on something else during the swim.
Good luck, and if I can do it, I’m sure you can too.
random ass idea but try burping. I make sure I burp every so often in races because if I don’t I get nauseous although in my case I think it has to do with my breathing…
Avoid swimming on a completely empty stomach. If the taste of the water is distasteful to you try chewing gum before the start of the swim and/or brush your teeth.
Wear ear plugs in cold water.
If you become queasy with your face underwater raise your face above the surface and look at the horizon for a few moments.
On the plus side, when you vomit, all the pretty fishies come to eat the barf…
Most of it is mental. Imagine you are one with the ocean. It is rocking you side to side, like a baby. Notice any patterns to the swells - you’ll start anticipating their movement.
“If you become queasy with your face underwater raise your face above the surface and look at the horizon for a few moments.”
If you’re motion sensitive, the LAST thing you want to do is look at the horizon, going up and down, up and down!! That’s what got me into trouble the first time I went swimming in Hawaii. I quickly learned not to stop and look at the horizon!! You’re better off looking at the ocean floor and concentrating on anything down there. I’ve seen tires that look like doughnuts down there when your in 80’ of water. Very interesting sites and they keep your mind off your motion sensitivity. It worked for me.
