Numbness in hands
hello!
normally have numbness in my hands if im on the hoods of my bike..blade with STI--i ride in traffic but did a 20min tempo in the aerobars (PD split seconds) after 15mins had numbness/ pins and needles on both hands. was wearing gloves and wasnt gripping the bars that much…pads are almost underneath my elbows ( elbows are in line with my ears) great bike fit…
dennis
You’re probably pinching your ulnar nerve- it sneaks right through just medially to your elbow when you’re in the aerobars. If that’s the case you will be more numb towards your pinkie and outside of your hands. Try to move your arms more towards your body to keep the pressure point off your elbows/nerve.
Jodi
thanks J ill try that out..never had issues years back when i had a pair of syntace c2s, would the PD padding be an issue as well? being too thin? im not that big(5`9 154lbs) but ride pretty forward
It could be the padding, but also your arm may be at a slightly different angle (your hand might be rotated differently in the new set up). You can easily find that nerve to see what I’m talking about- It’s pretty thick. Feel between the 2 bones of your elbow. The nerve runs right through the groove. Find a position where your weight isn’t resting on this area. You might need to adjust the bars forward a little bit.
Good luck!
My hands always go numb when I’m in the hoods. It sucks, so I feel for you!
Jodi
yep. just felt it. i`ll make the adjustments on my pads, i think the PD are also too thin compared to the syntaces. thanks!
D
I completed a 7 plus hour ride in early October while preparing for Ironman Florida. Following the ride I noticed numbness on my pinkie and outside of my left hand. Believe it or not, it has not gone away…I can actually feel the numbness as I type away right now. Anyone know if this will ever go away?
I developed the same thing last June after/during a 7 day bicycle tour through the rockies. I was fitted with a splint to wear at night that prohibits bending of the elbow, which tends to be the place where the ulnar nerve gets irritated. I also took a heavy dose of Aleve for several weeks per my orthopedists instructions. The tingling/numbness has gone down slightly, but it is still there 6 months later.
I also had this last summer. I had a lot of muscle weakness as well. During the ride where I injured it I bonked really badly (don’t know if that has anything to do with it) and by the end of the ride I needed to use my right hand to shift my front derailer. It was bad.
Took several months to totally go away, but now I’m back to normal. I got it from my road bike and it was from pressure on my ulnar nerve in my hand (not elbow, as is the case on a tri-bike). Need to buy much better gloves and switch positions often.
Jodi
If I’m not careful about where I place my left arm on the pad my arm from my elbow down will go numb in less than 5 minutes. All I have to do is move it back just the smallest amount and everything is fine. No problems with my right arm.
