All of a sudden, I don’t get notifications when someone replies to one of my posts
This is new behavior. It started about 2 days ago
Anyone else ?
Is there a setting that I may have accidentally turned them off ?
Anyone else ?
Replied…did you get a notification?
I didn’t. Did you ?
Not working for me either.
Ok. I am glad I am not alone.
I do get like notifications
We recently upgraded our Discourse back end – so might have something to do with that. I’ll investigate.
Also moved this thread to the appropriate subforum…
Quick update – it looks like you may need to clear out your notification history, as there’s a default max number of notifications in place. (click your user icon in the upper right hand corner, there should be a dismiss at the bottom of that list…that seems to have cleaned up behavior on my end as I got the notification @Lagoon had liked my prior reply).
No other settings have changed on the Discourse side so…that’s my initial recommendation.
not sure where the dismiss is
I see this, and the ‘dismiss all’ is greyed out
I do get ‘like’ notifications, just not replies
I see the same thing.
That’s the wrong page. Click your little icon in the top right then at the bottom of that new menu is dismiss.
I didn’t do that before a few notifications showed up so not sure what is going on.
YT links also aren’t expanding @rrheisler
