Non Plastic Water Bottles: What are the options?
Trying to kick the plastic water bottle habit. Sick of tops that don’t match, worrying about plastic chemical leaching, and producing yet more trash. Looking for advice on what’s available and what works. Must fit a standard bottle cage, stay in place, and be single hand friendly - just like a plastic bottle. What have you used? Save me some grief by telling me what didn’t work for you. Thx.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250465692929&rvr_id
A lot of people think that metal leeches, too. I bet it’s far more reactive to the environment; if you left a plastic bottle in a landfill and whatever metal one you’ll use, which do you think would last longer?
Sigg bottles work well. Or if you can find them knock off aluminum bottles w/ sports lids.
www.mysigg.com
Hey BeanBug, I remember you from Tri Newbies Online.
Point taken, but your body can use and even needs certain metals. Magnesium and iron come to mind. It definitely doesnt need plastic in any form.
One and the same :slight_smile: I’ve been MIA since starting my last phase of school. I went back and realized a lot of the old posters had come over here so I’m making the tentative transition. LOL. Nice to see you Paul.
Good Points
The biggest issues these day seem to be the carcinogens. Especially in plastics and in my experience any one who is concerned about the environmental plastic of plastic will know how to recycle both plastic and old aluminum water bottles. There is a company called Klean Kanteen that uses stainless steel (non toxic) but they don’t have the sports tops.
http://www.kleankanteen.com/products/classic/klean-kanteen-40oz-classic.html
Just checked out the Kleen Kanteen website. Yes, they are indeed stainless steel bottles. Better still - they have a “sport top” accessory. Looks like it will work. The remaining question: do they work with bottle cages? I’ll contact them and inquire. Thanks for the tip.
You’re welcome. I’ve been toying with making the switch for two years so Let me know if they are cage compatible. I just can’t seem to make myself throw away the plastic bottles (even in a recycling bin) until they are on their last legs. But as soon as they die I’m going the healthier metal route.
Point taken, but your body can use and even needs certain metals. Magnesium and iron come to mind. It definitely doesnt need plastic in any form.Men generally have too much iron as it is, which is why multivitamins for men now don’t typically add iron, so you could be adding more of what you don’t want.
Aluminum has been linked in some way to alzheimers though the jury is still out.
There is at least one company - whose name I forgot but will try to find that is headed up by triathlon legend Andrew McNaughton - which is trying to make a biodegradable sports bottle. But, as much as a biodegradable bottle is a good option, a bottle that doesn’t biodegrade - but which you don’t throw away - like a stainless steel bottle is probably a better one overall.
I have some of the KleanKanteen bottles. They make a bike cage for their bottles but it must be non-standard width (more narrow). The Bottles (800 ml) are also quite tall so could be an issue in some frames. You can order the plain silver ones from them directly with the sport top. If you want a colored bottle and a sport top - then I bought mine from Greenfeet as you can mix/match bottles/tops. Greenfeet was out of the cages so I haven’t tried that yet but plan to.
Drinking out of the sport tops is easy - you can’t squeeze the bottle unless you’re really strong but water flows well with some sucking. The air valve does squeek when you drink so if you’re in a quiet room - its noticeable…
The sport top does have an air valve that will also slowly leak if you turn the bottle upside down. I think I have the Sport Top #2.
Overall I really like the bottles and feel more “green” - though again haven’t really tested them on the bike yet.
They are sl. heavier than plastic but make a better weapon. Narrower = more aero :).
Dave
Option 1: Dehydration
Option 2: Cancer
Option 3: Endocrine disruption
LOL and we all know anything that is more aero is automatically better. I bet w/ the extra weight behind them they go farther and faster too.
something really cool is coming soon from Specialized.
x2 on SIGG
I have some Sigg bottles. They fit in a regular cage and work quite well. They do rattle in a metal cage which can be annoying depending on road surface. I don’t like them for mountain biking because of the clanking noise over the bumps.
