Non coded hrm strap with replaceable batteries
Does anyone know of such a product? I have the polar t31 now for my polar watch and it works with my powertap too. But, every time you run out of batteries you need a new one. I have seen them with replaceable batteries but are these only the coded ones?
Thanks a lot,
Dan
www.aiatriathlon.com
I’m not aware of any but you might want to check the Polar site. They have supposedly discontinued the ones without batteries in favor of the new flexible ones with the replaceable batteries. I thougt I had seen where there was a chart showing that the new battery replaceables ones were backward compatible with the earlier ones.
Barb
You can use the wearlink strap with any polar watch. If it’s a coded watch, it’ll work coded. If it is not a coded watch, it will NOT work coded. There it is. Buy the wearlink.
Eric
You can buy extra straps from PowerTap or from SRM (not sure since they switched to coded on new CPU) that are not coded as well as Performance sometimes.
Hey Eric, even though it is coded it will work with my non coded powertap and polar watch? But the t31 coded won’t work right? Does the wearlink determine whether your watch is coded or not before transmitting?
Thanks,
Dan
If you need coded, you have to use two coded pieces. (Watch and transmitter)
If your watch is coded and your transmitter is not, then the system will not work as coded, but will work to give HR.
If your transmitter is coded and your watch is not, then the system will not work as coded, but will work to give HR.
I just set up someone’s watch (old model A3 polar) with a wearlink strap. The watch was not coded, but the strap is. They worked together. I don’t know about the Power Tap, though. Hope this helps.
Eric
