Non-bouncing beam bikes?
OK, I’m still looking at buying a tri bike for next season. My first instinct is to go with the Cervelo Dual. My other option is a Softride Classic, seeing as how Dan says I can get one for about $1600.
Here’s my concern with the Softride: I don’t want to be bouncing around like I’m riding a bicycle/pogo stick hybrid. (Let’s not even get into how I just need to pedal smoothly, OK? I figure I might eventually get to that point, but I don’t want to look like a complete idiot in the meantime.) Is there any way to limit the amount of bounce in a Softride? (And I know some people consider that give a feature, not a drawback, but I’m not one of them.)
Are there any other beam bikes out there that don’t bounce?
If you do, your pedal stroke is probably already smooth enough not to bounce. I have a Rocket and have never felt like or been told that I’m bouncing.
It helps to make sure it fits correctly.
I love my softride.
My brother rode one for a couple of years. The few times i rode it I certainly never had the feeling the beam was bouncing (at least after the first few minutes of me trying to see just how far you could get the beam to bend by bunny-hopping and landing while seated…try THAT on a rigid frame…bye-bye nuts). If you’ve ridden a bike for more than a week I think you should be fine, and with your screen name I think it’s a safe bet.
Enjoy it.
This is a triathalon forum. Please move your posts about your bouncing beam to the Lavender Room.
If you get the correct beam I doubt you’ll have problems. Ask Adam at SR for a test ride opportunity. As long as you aren’t yo-yoing on the thing you’ll even the stroke out in time. If you plan to be by my neck of the woods I’d let you ride one of mine.
Get a Rocket. I don’t bounce unless I spin in too high of a gear.
A few comments here:
Answer 1: The beam only reflects the loads placed upon it. Unlike a rigid frame, a beam will adapt to your body instead of forcing you to adapt to the frame. If your pedal stroke isn’t smooth (round) or efficient, the beam will let you know by moving up and down. As you ride more on a Softride and your stroke improves, the bobbing will disappear. Unlike any other frame, a Softride can help you become a better rider by giving you feedback. Below is 1987 Tour de France Champion Stephan Roche’s take on beam motion:
“In the beginning. I rode with the beam for 100 yards and I did go up and down quite a bit…So, I brought it back to my house and put it into the corner. I felt it wasn’t possible to ride the bike without bouncing. Then, the Softride people told me to give it a little more time. I took the bike out a week later, and gave it a three-hour spin - and now I don’t want to give up the beam. It’s definitely special.” - Stephan Roche, 1987 Tour de France Champion
Answer 2: Beam motion can be caused by improper saddle height. If your saddle is too high or too low, your muscles are unable to revolve smoothly and will cause the beam to bob. For example, if your saddle is too high on a rigid bike your hips are forced to extend out of the hip joint on every revolution. On a beam, the hips will stay in joint with every revolution, but the beam will pull down instead. The result is bob. The solution is to adjust the saddle.
Answer 3: Beam motion will be cut down drastically as the rider becomes more experienced riding the bike. However, even if there is some beam motion, Softride design is not sacrificing power and efficiency into the drivetrain the way many frame suspension systems do. The drivetrain is still 100% rigid and, because of its compact size and stiff aluminum construction, is actually one of the more efficient power distributing drivetrains available.
If you care to test ride a Softride shoot me an e-mail @ adam.greene@softride.com or info@softride.com
The TitanFlex boom comes in 4 levels of flex. I have the “softest” i.e. most flexible, and it is much less flexy than my Softride Rocket, yet still absorbs all the road chatter. Think about the difference between a BMW suspension and a 1977 Cadillac cream puff.
www.titanflex-usa.com
Titan Flex has a boom that is rated to hold over 300 lb. rider. That’s stiff. I’m 185 +/-, have the next to the most flexible, and find it very nice. My riding buddies say they can see the beam moving, but, I don’t usually feel it. I also don’t feel the rough road on my rear! As far as the stiffness of the rest of the bike, it’s stiffer than anything else I’ve ever stood up and cranked hard upon. It’s easy to stand to pedal on the Titan Flex, too, the beam is located low…just like on a regular double diamond frame, so, it doesn’t tend to slap the inside of your thighs (like some beamed bikes can) if you rock the bike back and forth when climbing or sprinting.
Get a Rocket.
Does it bounce less?
I know there’s a difference between the Classic and the Rocket in how the beam is attached to the frame. What purpose does each style serve?
Below I have listed some comments that have to do with the differences in function and design between the Classic and Rocket/FASTT beams.
Classic (Qualifier,TT, Solo, and Lite): The Classic beam is the best example of all that beam suspension technology offers. It is designed for those people who are open to understanding all the benefits beam technology offers and who understand that the more comfortable they are, the better their body will be able to perform. The Classic beam maximizes the Performance Advantages of comfort, reduced rolling resistance, cornering traction and adjustability, all the while still offering a responsive and aerodynamic chassis.
Rocket/FASTT: The Rocket/FASTT is stiffer and lighter than the Classic beam and thus helps to bridge the gap between traditional rigid frames and suspension technoolgy. The Rocket/FASTT is designed to maximize the Performance Advantages of frame stiffness and aerodynamics while still providing the rider with greater comfort, better handling and less rolling resistance than a rigid frame at the same time. The Rocket/FASTT provides a more “traditional” ride and doesn’t take as long to get used to as the Classic Beam. The Rocket is designed for riders 200lb and under. If you are over 200lb, please consider a Classic beam frame.
Adam
Softride Bike
www.softride.com
I’m anything but an expert, but I do know that the Rocket doesn’t support as much weight as the classic beam. (the rocket beam’s rider weight restriction is lower than the classic beam restriction)
As for me, I don’t think I have any bounce. I certainly don’t feel a bounce (unless I spin in too high of a gear) and I’ve never had anyone comment that I bounce.
When I’m in races, it seems like the only Softrides that I see w/ a bounce is the classic beam riders (I don’t have any recall of seeing a rocket rider bounce). However, that may be a function of riders and not the bikes (maybe rocket riders are more experienced/better riders???).
I suspect that the classic beam just isn’t as rigid as the rocket beam. This increased flex likely lends itself to a greater bounce.
I’m not saying that all classic beam riders will bounce. But I do suspect though that pedal inefficiencies aren’t as masked on the classic beam.
A lot of rambling in my response. Not sure if I gave you an answer.
I think that you should tet ride a classic beam before choosing one over the other. Test ride a titan as well if possible but I think that will be a more diffucult option.
I find that I had little bounce on my classic beam after the first month or so. My training buddies also commented that I was faster on the flats & rollers as well.
I’ve been riding a Softride Qualifier for two years now, and don’t notice the bounce. I think it is pretty fair to say that my pedal stroke is far from smooth.
TitanFlex.
-Robert
Do you ride rollers?
LOL! No, when I fall off a stationary bike, I do it like a man- outside, to the ashpalt, in plain view of the public.
Thanks to everyone for the advice. I’m gonna mull it over for awhile. Maybe see if I can get a test ride from a local dealer.
Buy one of these, well, buy one LIKE one of these, they are not for sale!! : ) http://img1.uploadimages.net/048634IM000147.JPG
If you can, test a classic with the stiffest possible beam. If that is not to your liking, go with the rocket. I have both the classic and the rocket style frames. I am one of those people that like the plush ride of the classic beam. The rocket is stiffer and lighter, hence the race bike.
I got wood looking at those Zipp bikes.
I used to ride a Sofride Classic, back then called the PowerWing. Changed to a double diamond normal bike as my back healed up and when I wanted to move to 700c wheels. The Softride did have the plushest ride I’ve ever experienced and although you bounced quite a bit when you first got on it, after a week or two in the saddle the bouncing is virtually gone. And as Softride will so quickly point out, the beam acts as active feedback so you can better your stroke.
If you end up wanting to spend more and get a Rocket, this would be my choice unless I was riding on horrible horrible roads and had a bad back, send me a personal message if you would be buying a medium. I have a friend with an in the box Rocket TT in I think a size med. The price he was asking was around $1400 which is around half of retail and $200 cheaper than the current Softride promo going on.
Good luck with the bike buying.
