No rear wheel cutout on XS Lucero--why?
Have been doing some research in case I decide to catch an end of year sale. Read a lot of past ST posts about the Lucero…and learned there is no rear cutout on the XS.
My question: If the cutout aids in aerodynamics, then why are the little bikes/little people screwed out of this?
And if it doesn’t, then why put it on any of the sizes?
thanks!
650c wheels. It’s pretty common for makers to nix the cutout for 650 bikes.
realizing they are diff. wheel sizes, but Cervelo keeps the cutout on the little bikes.
So my question remains…would I be as aerodynamic? and if not, then it is a sort of discrimination against the little bikes/people. If the aerodynamics are the same, then what’s the point of the cutout in the first place?
I’m pretty sure it’s because (like other manufacturers) they use the same rear triangle for all bikes, so the chainstay length is the same for all sizes. If the XS uses 650c wheels and the chainstay is the same length, then a cutout is not necessary because the smaller-diameter wheel won’t even reach the seattube.
Ok…so manufacturing has been addressed…
But can someone please answer my question about aerodynamic benefit or not?
OK…I searched some more and found this thread…
http://forum.slowtwitch.com/gforum.cgi?post=719416;search_string=rear%20wheel%20cutout%20lucero;#719416
which indicates that the cutout may not be of much value…BUT STILL…why not for the little people if the big people get that advantage (even if a small advantage)?
What is all this crap about the little people being discriminated… give me a break…
as they said the 650 wheel makes it a bit tough to put a cutout in there. Cervelo does it but they have super short chainstays and their sweeping seat tube design gives a bit more material which to cut out of, ie as it sweeps rearward as it goes up it hits overlaps the tire more and allows a bit more room to do the cut out, or something like that, maybe i’m just making that all up:P I don’t really know the downsides of super short chainstays but I don’t think the cut out is a real negative on that frame. As others noted it’s pretty rare to find a bike in that size with a cutout. The Lucero xs is a really nice bike though. Built one up for a friend and she loves it. Went out riding with her this morning and she was killing me pulling off the front!!
If they used the same rear triangle as the 700C bikes the BB drop would be screwed up on a 650 wouldn’t it? The pedals would be too low to the ground.
jaretj
if you can’t answer the question, then never mind.
At least Cervelo has the technology to make a different rear triangle for small bikes to give the same aerodynamics/aesthetics as the larger bikes.
Thanks to all for answering the engineering question that I didn’t ask. Thanks to no one for addressing aerodynamics.
bt,
Aerodynamics of a frame always come second to what? thats right position/handling/comfort…
Quintana Roo wants to keep a certain length of wheelbase on their bikes. They opt for 386 on 650s, other companyies like Cervelo go for around 365.
Thanks for a more solid answer. Seeing as how I’ve loved my P2K for 4 years (small bike/650 wheels/rear wheel cutout), I suppose I’ll lean toward the P2C until I get a chance to test-ride the Lucero.
Appreciate your answer.
I have been riding the Lucero since April. The bike is awesome and very aerodynamic. And it fits me like a T. I cant say enough good things about the Lucero. I highly recommend it.
jaretj
Can you think of another reason why the chainstay length is exactly the same on 650c and 700c models? On the Cervelo’s the 650c chainstay is 12mm shorter.
Because little people are too small to create wind resistance? Or because QR likes Randy Newman:
Short People got no reason
To live
They got little hands
And little eyes
And they walk around
Tellin’ great big lies
They got little noses
And tiny little teeth
They wear platform shoes
On their nasty little feet
Well I don’t want no Short People
Don’t want no Short People
Round here
Short People are just the same
As you and I
(A Fool Such As I)
All men are brothers
Until the day they die
(It’s A Wonderful World)
Short People got nobody
To love
They got little baby legs
And they stand so low
You got to pick ‘em up
Just to say hello
They got little cars
That got beep, beep, beep
They got little voices
Goin’ peep, peep, peep
They got grubby little fingers
And dirty little minds
They’re gonna get you every time
Well, I don’t want no Short People
'Round here
No, the midgets would be using leetle tiny cranks :slight_smile:
Edit: should have been a reply to jaretj
I think shifting would work better with the longer chainstays.
If they did use the same rear triangle and just rotated it up a little, the seatstays would have to be a little bit longer.
But having longer chainstays kind of defeats one of the purposes of using 650 wheels and that is to get the rear wheel more under the rider so the front/back weight distrubution is better.
Thats just off the top of my head, they must have had a plan when designing that bike. QR is a good company
jaretj
I’m probably one of the biggest triathletes on this forum in stature. Dammit, I think i’m entitled to a cutout of epic proportions…
I would but I just can find any 148’s :frowning:
jaretj
You said you’re a ‘little person’ right? Well, you’re already more aerodynamic than us big 6 footers. :wink:
