No love for Biopace on ST? Read Sheldon Brown Review
Seems like Biopace should make sense. I had some pretty good riding back in 1988-90 on biopace. Food for thought from Seldon Brown:
http://sheldonbrown.com/biopace.html by Sheldon “Better Than Round” Brown
From the time of the invention of the chain driven bicycle, the possibility has existed to use non-round chainwheels to vary the mechanical advantage (gear ratio) according to the position of the cranks at any given instant. There have been two basically different and contradictory approaches to this:
Traditional Elliptical Chainweels
Around the turn of the century, shortly after the development of the chain driven bicycle, someone came up with the bright idea of elliptical chainwheels. The idea was that the large radius of the chainwheel would drive the chain when the cranks are horizontal and the small radius would pull the chain when the cranks are vertical.
The theory was that while the cranks are horizontal you can pedal more efficiently, and thus can push a higher gear. When the cranks are vertical, you get a lower gear due to the smaller effective radius of the chainwheel. The lower gear is easier to push, and you get through the dead spot sooner. This looks great on paper, but doesn’t work out so well in practice.
The major problem is that this design tends to hurt people’s knees. The high gear when the cranks are horizontal encourages the rider to push too hard, and we all know that pushing too high a gear is a common cause of knee problems. In addition, the low gear when the cranks are vertical means that the knees are moving extra fast when they are changing direction from going up to down and vice versa. This “whiplash” effect caused most users to abandon elliptical chainwheels. Ever since the chain driven bicycle was invented, elliptical chainwheels have been re-invented and re-abandoned for the same reason every ten or fifteen years.
Biopace
Biopace is a patented non-round chainwheel design made and licensed by Shimano. To a casual glance they resemble elliptical chainwheels, but on closer examination they turn out to be the exact opposite of the classical elliptical design. The product of extensive research and computer-aided design, Biopace chainwheels have the small radius engaged when the cranks are horizontal, the large when they are vertical. This is because the Biopace design is based on a dynamic analysis of the motion and momentum of moving cranks and legs, unlike the static, geometric analysis that produced classical ellipticals.
The theory is that during the power stroke, when the cranks are more or less horizontal, you are using the power of your legs to accelerate your feet, which get going quite fast in the lower gear provided for that part of the stroke. The momentum of your feet then carries the pedals through the “dead spot” when the cranks are near vertical. Since the rider doesn’t push as hard during the power phase of the stroke, and motion is slower when the leg is changing direction, the Biopace design is gentler on the knees than even round chainwheels.
What Are They Good For?
Biopace chainwheels are particularly suitable for touring cyclists and time trialists, or any application that involves a steady, fairly constant cadence. They allow healthy, efficient pedaling at slower cadences than is possible with round chainwheels. They are especially suitable for triathletes and mountain bikers. The triathlete benefits because the motion is a little bit closer to that of running, making the transition easier.
The mountain biker particularly benefits, because the Biopace design somewhat smooths out the delivery of power to the rear wheel. In climbing on loose surfaces, the limiting factor is often traction. The rear wheel tends to break loose during the maximum power phase of the pedal stroke, wasting most of the cyclist’s energy. The Biopace chainwheel works like a storage device, storing power during the main power phase of the stroke as the feet accelerate, then delivering the stored power to the rear wheel during the “dead center” phase when the cranks are near vertical. The same average amount of power is delivered to the rear wheel, but in a smoother, less pulsating flow. All the energy is used to propel the bike forward, without the high-power peaks spinning the rear tire or causing the bike to “wheelie.” The Cadence Issue The marketers of Biopace made a crucial error of judgement: too much information. In particular, they mentioned that the Biopace design was optimized for cadences of about 90 rpm and slower. Many readers interpreted this as an indication that Biopace chainrings would somehow interfere with pedaling faster than that. This perception caused a bit of a self-fullfiling prophecy, and the Conventional Wisdom arose that Biopace was bad for high-performance cyclists for this reason. I used to believe this myself, but I rode them anyway because I appreciated their other virtues.
Among other bikes, I run Biopace on several of my fixed-gear machines, where high cadences are quite common in descending hills. In practice I have found no less ability to spin fast with Biopace chainrings, and, if anything, they permit me to spin faster without bouncing in the saddle.
Here’s why: While your feet go around in circles, your legs basically go up and down in a reciprocating motion. With Biopace chainrigs, your leg speed is faster in the middle of the stroke (when the cranks are horizontal) but slower at the top and bottom of the stroke (when the cranks are vertical.)
The slower motion at top and bottom means that as your leg changes direction from upward to downward, or downward to upward motion, it will do so at a slightly slower, more gentle speed. The increased leg speed near the middle of the stroke is the result of a more gradual accelleration/decelleration with the leg moving in the same direction. Bouncing in the saddle generally results from difficulty with changes in leg direction, not speed in the middle of the stroke. Thus, as Biopace makes it easier on your knees, it also can help you spin faster without bouncing!
Mixing Biopace and Round Chainwheels
It is possible to mix Biopace and round chainwheels on the same crankset, but I would not recommend it. When chainwheels are mixed, it is usually a small Biopace with a large round ring. The idea is to take advantage of the Biopace’s superior climbing performance at low RPM’s, and have the big round ring for descending and spinning fast.
The problem is that Biopace rings are more comfortable at low RPM’s, and round rings at high RPM’s. When you shift from a small Biopace ring to larger round ring, you go from a fast cadence on the Biopace to a slower cadence on the round ring–just the opposite of what is wanted. I have tried this arrangement on both a road bike and a mountain bike, and found it extremely irritating.
The opposite arrangement (large Biopace/small round) makes even less sense. If you like the large Biopace, you will like a small one too. The only reason I can think of for setting up a bike this way is if you need a lower low gear than you can get with Biopace. For instance, the smallest Biopace for the 74 mm bolt circle is a 26, but you can get a 24 tooth round ring in that size. For the 110 mm bolt circle the limit is 36 teeth Biopace vs. 33 teeth round; for the 130 mm bolt circle, 42 teeth Biopace, 38 teeth round. Biopace and Fixed Gear People are often astonished to learn that I ride Biopace chainrings on fixed-gear bikes. They imagine that there will be tremendous changes in chain tension as the chainring rotates. In practice, this is not the case. A 42 tooth chainring will generally engage 21 teeth against 21 chain rollers, regardless of its shape.
There is a sligth variation in tension resulting from the varying angle between the two straight runs of chain as the axis of the chainring rotates, but this has not generally been of a sufficient magnitude to cause any problem in practice for me. Conclusion
Biopace chainwheels were made by Shimano and were also made under license by some other manufacturers. The shape of genuine Biopace chainwheels is not a simple ellipse, but a more complicated shape which Shimano describes as a"point-symmetric egg curve." Other crankset makers have made similar designs, generally of simpler shape (pure elliptical) but oriented in a similar manner to Biopace chainwheels. Examples are SR’s “Ovaltech” and Sugino’s “Cycloid.”
Non-round chainwheels remain controversial, especially among racers who think that everyone should ride racing bikes, but, in my opinion, they are of real value for the vast majority of non-racing cyclists. Unfortunately, this useful option has become all-but-extinct.
Orientation For installing Biopace chainrings, the orientation should generally be preserved. Each Biopace chainring has an “indexing mark.” This is a small tab pointing inward toward the middle of the chainring.
For a normal upright bicycle, this index tab should be hidden behind the right crank.
For recumbents, the chainring should be rotated forward by 1 bolt position.
It’s all good - we just like Gary’s Q-rings better since they are “adjustable” where the down stroke begins and he is a fellow STers. :slight_smile: Not that this really matters, but I swear all the stuff I use/would buy, the CEO/pres, etc. is here (Paul Thomas - Kuota, Emilio, Gerard, Herbert, Elite-Dave, Frank Day, Tingley, etc. etc. What a great place this is …
Rod, true about Q rings and Gary. I’m just surprised they gradually faded away from Shimano’s offering. I think I actually have set of those biopace somewhere in the basement. Might be interesting in pulling them back out again but I wonder if 6 speed rings will now work with 10 speed chain…doubtful!
I rode Tupper on 54 Q-Ring and 42 Bio-pace. :slight_smile: (No theory just too lazy to switch out the bio pace out. :-)) Two different design concepts. Very noticable when when used together on the same bike. I like the Q rings better for Tupper Lake style rollers.
is that your secret for beating Triyoda…did the 6 speed biopace work with 9/10 speed chain?
No Yoda just dropped one of his gels…or that’s how the story goes. :slight_smile: No shifting problems… Q-Rings & Bio Pace a 9 speed chain and a 10 spd front der. :slight_smile:
I got an extra set of Dura Ace Bio Pace 42 if you want to try it.
I have BioPace 52/40 on my old roadie. It’s 7-speed and the chainrings say “narrow chain only” on them. Wonder if they’d work with a 10-speed chain. Hmmm…
Steve
i violate sheldon’s guidelines and ride a mix on my cruiser/city/touring machine (*): 48T round, 34/28 biopace. i also rotated my biopace position by 180 degrees to offer something closer to the Q-ring experience (long before Q-rings existed, though). i love the combination. nice smooth pedalling on the flat, biopace-assisted climbing. i’d love to go touring on this again, but thats not happening till the kids are gone.
(*) custom reynolds steel frame, crank bros cranks, 1989-era Deore XT derailleurs and freehub (6 cogs, count 'em!), moustache bars wrapped in GrabOn and cloth tape, Brooks B17 saddle, 1.2" tires, rivendell bar end shifters, fenders, baggins saddle bag. Retro for aging bike culturists …
“The major problem is that this design tends to hurt people’s knees. The high gear when the cranks are horizontal encourages the rider to push too hard, and we all know that pushing too high a gear is a common cause of knee problems.”
This logic escapes me. While a big gear may be related to knee problems in some people, how do we isolate which point of the pedal stroke causes injury when using a round ring? Why would pushing a big gear at the point of maximal biomechanical advantage be more harmful to the knees than trying to pull/push the same gear through the points of least biomechanical advantage (i.e., the deadspots)?
The fact is many people stopped using Biopace because they reportedly caused knee problems. Although annectdotal, that seems to support the idea that moving a big gear through the top/bottom of the pedal stroke is not such a good idea afterall. On the other hand, I have yet to hear of any reports on knee problems attributed to Q-Rings or chainrings of similar design.
My $.02
HAim
“On the other hand, I have yet to hear of any reports on knee problems attributed to Q-Rings”
I’ll go one further, I had some minor knee issues on my MTB which went away within a week or so of switching to Q-rings. Coincidence? I don’t think so. I don’t know all the science, but I do know that everyone I know who tried Q-rings notices the improvement and noone I know who tried them has gone back to round rings.
Everyone knows biopace and Q-rings are totally different, right? Just checking…
The difference between Q-rings and previous non circular chainrings
Q-Rings are elliptical; Biopace and O.SYMETRIC chainrings are asymmetrical. The specific elliptical shape of the Q-Rings provide a very smooth uniform pedaling stroke; there is no sudden acceleration movement.
Bio-Pace chainrings are designed so the maximum equivalent tooth size is at the dead-spots. Q-Rings have the minimum equivalent tooth size at the dead-spots. This enables you to pass through the dead-spots quicker with less stress to your knees.
Q-Rings take into consideration the forces from your legs in static conditions and the inertias of the cyclist and the bicycle. This maximizes the efficiency and comfort of conventional cranks.
The OCP System enables you to customize the position of the Q-Rings to suit your individual riding habits, body geometry, strength and position on the bike.
 **** **** ****  ![http://www.rotorcranks.com/images/compare-qrings.jpg](http://www.rotorcranks.com/images/compare-qrings.jpg) ![http://www.rotorcranks.com/images/compare-osymetric.jpg](http://www.rotorcranks.com/images/compare-osymetric.jpg) ![http://www.rotorcranks.com/images/compare-biopace.jpg](http://www.rotorcranks.com/images/compare-biopace.jpg)
