No... critique MY position!
http://photos-e.ak.fbcdn.net/hphotos-ak-snc1/hs121.snc1/5220_1190390556114_1118858947_30579196_857048_n.jpg
I think you need a smaller jersey, tri suit, tri top or whatever.
Smaller jersey, regular bottle horizontal between the bars and better number placement. Cut the actual number, just the “150” part, away from the background and use clear tape to tape the number to your seattube, downtube, whatever.
You look comfy and relaxed. Winner to me.
Are you wearing socks or is that your timing chip on your right ankle? There is a lot less chance of your timing chip getting caught in your chain ring if it’s on your left ankle…
d
Tape the rear vents completely for that helmet. It’s a good and aero helmet, but some of the venting was poorly conceived (added on by marketing people rather than the engineers). If you’re able to fill in the front vent, that would be good too. Too bad you don’t have the TT02 helmet that allows for addition of a visor… that would probably help, but you could always attempt to fashion one out of a coke bottle.
What is that cable that appears to extend upward from the 3 o’clock position of the chain ring?
brake cable.
and it’s supposed to be hanging out right there? I guess I never noticed that before on this model (note: I own a P2C)
Very nice position. But your seat’s too high. No really. But then again, this gives you more stomach clearance and I’m not sure it’s a bad thing to ride toe down.
An aero front wheel would help, as would the already-mentioned tighter top.
What Like this one??
http://www.cyclesuperstore.ie/shop/pc/catalog/medium/PRS690011.jpg
Way too high.
looks pretty good, would be hard to get your front much lower, the guys that get a really good position seem to have longer legs and smaller torsos. You could try the Zabriske shrug, practice rolling your shoulders inwards, this can reduce frontal area by up to a few Cms on each side, and frontal area is your biggest enemy.
I would lose the bottle cage for racing unless you are using it to hold a bottle.
Or they just ride smaller bikes…
To the OP: Seat is definitely too high.
you know, the best way to measure your position is to a roll down test. The best position is the fastest one that you can actual stay in.
Way too high.
Really you think? It looks like he has a lot of flexion in the knee and if you rotated him back into a road position his foot would be flat with about a 25-30% knee angle. The only reason I bring this is up is that it looks a lot like my position on a TT bike. If I drop the saddle I get some funky knee twinges.
Whoops…is that what he’s riding?
Way too high.
I hadn’t considered the different attack angle.
But the ankle flex looks so extreme that I have to say he’s at least a little higher than ideal. However, as I said before it’s possible that this is a good trade-off for stomach clearance.
Way too high.
Yes, I do. Moving forward from a standard road position to a typical TT/tri position only while keeping saddle height constant only changes various angles with respect to the horizontal by ~5 deg, and thus can’t account for his extreme plantar flexion.*
(*Note that the picture isn’t quite level, so that the situation is even worse than it may at first appear.)
I knew the Jersey would get picked on… Team kit - bad sizing… That won’t happen again…
The wheel is PRO-4 Spoke… I’m sure I could go “aero’er”, but I’m not sure how much more…
The seat height is one that I’ve played with for years… If I go lower, I feel it in my knees… Maybe I’m trying to go TOO low.
On the “foot angle” topic that seemed to get more attention than anything else, are folks saying that my “toe down” position will be eliminated by simply lowering the seat?
Thanks!
Bobby
