Newton Distance Stability Racer vs Asic DS Racer Sizing
Has anybody used both these shoes? Just want to know if a size 12 in the Asics DS Racer is the same as a size 12 Newton Distance Stability Racer.
I don’t have the DS trainer but, I used to run in the Gel Nimbus and GT 2110 and my Asics size was the same as Newtons.
Robert@Newton is frequent visitor here and may chime in to give more advice on size, as well.
FYI, if you decide to get the all-weather Newtons you may want to consider going a 1/2 size down, as the toe box is bigger (to accommodate thick socks, which I do not wear).
Thanks, I’ve been using the Stability Trainer in a size 12. Unfortunately the Stability Racer in the same size is a little bit bigger. I went for a run and my foot was sliding around alot and it felt very sloppy.
I should of mentioned too, that I have the Newton trainers, not the racers (haven’t tried them yet).
I went from the ds trainers to the stability trainers and I was a 9.5 in both, hope that helps
