If you are one of the people that think pedalling in circles is a good idea, and especially if you think one-legged pedalling drills are a good idea, there is simply NOTHING better to use than PowerCranks.
You have to pick up the rising leg (and everything to which it is attached) on EVERY pedal stroke…true for both legs if you have two legs…before you can push down. It trains your hip flexors and hamstrings to fire sufficiently and at the correct time in order to do this manuever. Once you have adapted to the basic motion, it’s time to learn to pedal when standing! You will be amazed at how pitiful your previous standing pedal stroke was…even more amazed at how pitiful you found out your seated pedal stroke was! You will really move up hills more quickly without the counter-pushing wasting forces that PC’s dis-allow.
If you’ve had knee pain pushing big gears in the past, take the initial adaptation phase easy, but, be prepared NOT to have knee pain. PC’s erased my knee pain problems that I had when time-trialling in bigger gears.
If you really feel like you cannot keep your mileage up when first getting on PC’s, I don’t know what to tell you to alleviate your fears, except, it didn’t bother my speed at all. It didn’t help my biking speed for a couple of months, then the gradual speed increase continued for the rest of the season. However, it helped my running speed almost immediately…especially my running speed when coming off the bike.
Usually, I rode 5-7 ten mile time trials on a club course per year. Last year, I was only able to ride the course once (after being on PC’s for 7 months) and set a PR by over 1 mph average speed (if I’m remembering correctly…don’t have my training log at my side).
I’m hooked on them because of the results I had. After years of declining run speeds, I now can run a 5K faster during a triathlon than I used to run a stand-alone 5K. I run training 5K’s at the speeds I used to run in a 5K race.
I asked Sonni Dyer, of Tri-My Coach, last May how his athletes that were training on PC’s were adapting. At that time, I believe he said he had 32 or 33 athletes on PC’s, and EVERY ONE of them set PRs on their runs within a few months of PC training. He had 170 athletes at the time…the other 138 athletes weren’t setting PR’s like that! Same coach; same basic workouts. Different results depending upon who had PowerCrank training.
It isn’t a fad or a ploy or a hoax. Even if it were, you have 60 days to make up your own mind, or get your money back. I’ll bet you won’t send them back if you train on them.
