Newbie - Or Out Of Shape American or How to buy a Bike or HELP
Hi all,
Have talked a few times about running a local sprint tri well finally started telling others I will do it this fall. So I have begun working out. Well Im 6’ 230 lbs and never been athletic. Have gone out and traveled 3 miles a few times last week took just over 40 min. Hopped on my 8 yr old Huffy mountain bike one day realized the rear tire was very low but for some dumb reason pressed on. Just over and hour later I had covered 6.5 miles.
Ok. I have looked at some training planes and think I may be pushing to hard and my knees are really sore so I will start following a training plan.
Have lots of questions about equipment for a newbie who may only do this one and no more. I like Biking and if I make the Sprint was thinking of working up to a century bike ride next year.
So figure I will be pushing to finish what is the minimal equipment/clothing I need? Do most people just wear tri-suits or Bike shorts and Shirts?
Ah a bike ya I will be getting a road bike. Started looking at hybrids cause this will be the bike I ride around the neighborhood with the kids but then I tried a road bike and just remember riding my old schwinn ten speed when I was in High School. (Would lose my license so road it a lot to my Girlfriend’s about 15miles ).
On bikes I would like to try some out but one of the (what appears to be) highly respected road/tri bike shops in the area doesn’t do test rides. I feel a bit uncomfortable going in getting fitted having a bike ordered buying it then riding it for the first time. What if I just don’t like it. The road bike I road was a hard ride and I want something a bit softer/smoother? I also feel a bit cheesy going to other stores to ride then going to them to buy. Any suggestions?
Also when buying a bike started (before the tri and century idea) I was looking at $300 - $600. Then it moved to $500 - $1k, now some are recommending up to $1.5K.
Can I get a nice road bike in the $600 range or what do I need to spend to get a good bike.
Thanks in advance, I’m sure I will get lots of answers.
This is probably too much info, but if you are looking for a road bike in the under $700 range I think they covered them all.
http://www.bikeforums.net/showthread.php?t=69273
Nice forum to browse, I don’t post there much as they are not as friendly as here.
Dave, (assuming that is your name)
That’s a lot to digest man. Here are a few thoughts that’ll not be too exhaustive in detail, and will bump your thread back to the top for others to further clarify or give their opinion. I believe a steel frame might be best, but there are others here that can elucidate, as there are quite a few big guys on this forum. I tend to dive into things 100%, and if you are the same I’d say spend as much as you can afford to, nice bikes are much more fun to ride. If you really want to lose some weight, it’ll take a while, as I’m sure you know. So buy one or two pair of nice bibs, that’ll probably run you at least $100 each. This is kind of an expensive game to play, but bibs make riding a pleasure, especially if you are on a “hard” riding bike. Hybrids are cool, especially if you are riding around the neighborhood with kids. Road specific bikes aren’t generall the type you cruise around the block in and jump off curbs and ride through people’s gardens :wink: Running is a very destructive process for all but the most durable/rail thin folks. Don’t worry too much about mileage at first, just keep it relaxed, which may be a humbling experience, and really listen to your body. It will notify you of acute pain, loosely defined as being specific to an area that is just a couple square inches, and that is when you suck up your pride and walk the rest of the way home, so you are able to run again the next day, instead of the next month. If your knees hurt, try walking or swimming. You should definitely be able to test ride a bike if they have one on the floor. Set a few more goals in between now and the Century ride, to keep you motivated. Keep asking questions.
A bump for the monday morning crowd
Dav: I too am 6-0, 230. I did five duathlons this past year on a hybrid and using the Galloway run/walk method was able to do six 5Ks, a 15K and a half marathon without any major injury and or pain.
I just bought a new bike, a Felt F60 road bike and am planning a full slate of duathlons, hopefully my first triathlon, and other events in 2005, including a full marathon.
I just turned 54 and realize that speed is no longer of the essence on the run and the bottom line for me is just being able to compete and enjoy the experiences.
Mark
Slowman just wrote a good review on Felt Road bikes last week. I memember seeing one of them was designed with the larger rider in mind.
Here is the link, good luck. http://www.slowtwitch.com/mainheadings/product2005/roadbikes/feltroad.html
Get a road tire for the rear of your Huffy, buy a fluid trainer (Kurt Kinetric or Cyclops), some Spinervals DVDs, some bike shorts, and start riding at home for a month or two. If you still like the riding after that time, go buy a new road bike. If you can get fitted for a bike, even better.
If you decide that riding isn’t for you, you’ll be able to sell the fluid trainer and the DVDs. If you like the riding, you’ll be in shape for the road or tri bike search. Good luck!
Compared to a hybrid or mt bike with soft tires, every road bike is going to feel pretty harsh, regardless of the frame material. You will get used to it eventually. Cycling gloves and shorts help with road vibration and saddle discomfort. Your knees may be sore from pushing too big a gear. Choose a gear to keep the pedals turning over at 85-100 rpm. I would buy from the store that helps you out the most and has a bike that fits you and your budget.
Hi Dave, Congratulations about jumping in, the hardest part is behind you!
I had a friend buy a specialized Allez last year. He went with the allez comp which is a little bit highly priced for the first time I’m not sure I like this stuff just yet person. But you can get an allez model that is a little less expensive < 1000 but a good starter. It would come with a 105 package that is fine for starting out. Oh yeah and my buddy is 280 lbs and did his first century with us last summer. So I wouldn’t worry about being too big for the aluminum frame.
I agree with other posters who have said that you should be able to ride a bike before buying it. If they are serious about that rule leave, and find a store that will let you test ride. You wouldn’t buy a car without a test drive would you?
At your current weight I would avoid carbon fiber though. Wait till you start dropping the weight before going that route.
Make small reachable goals, attain them then set the next, you’ll be doing that century before you know it.
I say, find a training plan you can stick to. You might also look into some populat books to familiarize you with training, multisport, and help define your commitments and get you rolling. My fav’s are:
Triathlon 101: Essentials for Multisport Success – by John M. Mora
Training Plans for Multisport Athletes (Ultimate Training Series)
by Gale Bernhardt
both are under $12 at amazon. They will help you quite a bit from a newbie perspective.
As for your bike. I like the idea of using your bike on a trainer. It will get your muscles into shape. Maybe look into some REALLY basic fitting sites to make sure you are in the right ballpark as far as your existing bike goes. IF you are truly dedicated come spring, either spring for a beginner bike $400-900, and give another try. Or, just throw slicks on your mountain bike and try a few races. I see a few dozen beginners at every race chugging along on mountain bikes. They aren’t as fast, and are very heavy, but you can defnately finish a race in one, and when you do get a road bike, MAN wil you be fast. Also, if you just can’t get comfy on a road bike, try a big fat padded saddle, padded shorts, even a padded seat cover until your taint can harden up some. You will eventually get used to it.
With swimming, unless you already have experience, you might look into “total immersion”. It is a pretty popular way to learn how to swim “right”, without all of the miles of laps you might expect. STart now and be a good swimmer by racing season.
As far as running, get some super nice shoes. Splurge. Go to a top-notch running store that can check your gait and get you the right shoe. then put in lots of miles. Take it easy, and stick to your training plan. If you’ve got some extra dough, maybe get a heart rate monitor as an incentive tool, and to make sure you aren’t going to hard. As said before stay tuned to your body’s messages and increase milage and time little by little.
Then, go do a race or two and see if you like it enough to start spending all your hard earned time and money.
As far as the century goes, get a lot of shorter rides under your belt first. You’ll thank yourself.
