New tubular rim strip?
I don’t know what it’s called but I did such a good job with the glue when I pulled the tire off to adjust it a bit since I still had a little bump, part of the strip on the bottom of the tubular came off.
So is there a way to replace that since the tubular is still pretty new.
you mean the base tape, right?
there’s a company that can fix this called Tire Alert (http://www.tirealert.com/tirealert/Welcome.html). They’ll basically take off the original and put on a new base tape. I sent them two of my pretty new tires, though i haven’t used the tires yet.
Others can probably chime in on their experiences.
They’ll also replace the inner tube if you get a flat when your tire still has a lot of tread left, though the new tube will be butyl instead of latex
Yeah the base tape couldn’t figure out the right word for it. 14 bucks awesome, I’ll do that.
Thanks a lot.
